when I had my 32gts4 I dynoed it at 110kw atw (basically stock), but fast enough for me over a twisty mountan pass (and quick enough to keep up with a friend in a gtr - ok mabey he was holding back a bit because he had my girlfriend in the car, but she was still sh!tscared)
well im just really asking if its even possible to have 180kw with low boost using the right equipment?? Just curious. I was reading one the import magazines and it was going on about a consevative way of modding and it said that the point on modifying a turbo would be be trying to the most power out of it using the least amount of boost increase. So hence why I was asking if its even possible to have good numbers with low boost.
dont know why you would want to buy a new turbo to run 7-8psi.....run the stock turbo with stock boost controller with a decent exhaust, split dump pip,hiflow cat, 3" system, pod should get you to around 170kw.....raise boost to say 10psi which is still safe and you will have what u are looking for......this is alot cheaper then upgrading ur turbo, cause u would have to get an exhaust anyway....my 2 cents....
i got 188rwkw with hybrid FMIC, HKS pod, turbo back exhaust w/dump pipe on stock boost @ uas dyno day last weekend. apparently i have a 'freak car' :sorcerer:
when i had the boost controller on previously, it ran 202rwkw at 11psi
damn you.....there are others with good figures from light mods
only changes i have made are
turbo back exhaust
just jap fmic
boost controller
202.6rwkw. Hit 11psi 2300rpm, got to 12psi by 4500rpm for a bit and dropped to 10psi by redline....
turbo back exhaust
just jap fmic
boost controller
WTF????? is that all you got?? No aftermarket ECU?? That car must be running rich as hell.
your kidding thats awesome man!!!! Is that your R33 in the pic doing the monster burn out?? I was under the impression R33 ECU's were the cars weakest link and the first think that needed to go. keeping the stock ecu in your case is mad cause its protected well due to ecu's protection in regards to running rich. Is this common for a boosted R33 running 180-200rwkw to run on a stock ecu well like yours. Or is your R33 some kind of freak of nature!!!
Edited by LatinR33
yeah it was at the drags....put on some old stockies and sat there for a bit...
i dont know too much about whats normal, or much about r33 ecu's being new to the scene but it seems to be going good. again not sure what others are running with stock ecu...some guys said i should check if it has been modified or chipped....but i really dont know too much about it....just fiddled with boost controller to set it up and chuckedf it on....
Sounds to me your cars just a freak of nature cause I dont think the R33 ecu can be chipped or modded. Thats mad!! Some other guy here I just read got 188kw's on just an exhaust,fuel pump and power fc!!! thats nuts I know Dyno's figures arent exactly accurate but thats still alright :P Must go good regardless.
i had 195 with exhaust and intercooler on 10psi stock turbo. even have the airbox in there. it just happens. maybe its just cars from the south west lol. it was running very rich, but still made a reasonable power curve, with the exception of a massive hole at 6-7krpm. but still 195 lol.
since fitted exhaust cam gear, power fc and a few other jazz and with 12psi got 188 at the uas dyno day lol. put bosch 040 in the other day and will tune it again tomorow and see what i get, before fanging it on the skidpan on saturday :unsure:
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
    • I like this page, better than that silly turbo kit   https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/
    • That would be my Shoei helmet
    • Yes shipping here can be a pain, was about to purchase timing belt replacement kit, but it tends to get expensive due to shipping (and customs if importing from non-EU which the UK now falls under).
