when I had my 32gts4 I dynoed it at 110kw atw (basically stock), but fast enough for me over a twisty mountan pass (and quick enough to keep up with a friend in a gtr - ok mabey he was holding back a bit because he had my girlfriend in the car, but she was still sh!tscared)
well im just really asking if its even possible to have 180kw with low boost using the right equipment?? Just curious. I was reading one the import magazines and it was going on about a consevative way of modding and it said that the point on modifying a turbo would be be trying to the most power out of it using the least amount of boost increase. So hence why I was asking if its even possible to have good numbers with low boost.
dont know why you would want to buy a new turbo to run 7-8psi.....run the stock turbo with stock boost controller with a decent exhaust, split dump pip,hiflow cat, 3" system, pod should get you to around 170kw.....raise boost to say 10psi which is still safe and you will have what u are looking for......this is alot cheaper then upgrading ur turbo, cause u would have to get an exhaust anyway....my 2 cents....
i got 188rwkw with hybrid FMIC, HKS pod, turbo back exhaust w/dump pipe on stock boost @ uas dyno day last weekend. apparently i have a 'freak car' :sorcerer:
when i had the boost controller on previously, it ran 202rwkw at 11psi
damn you.....there are others with good figures from light mods
only changes i have made are
turbo back exhaust
just jap fmic
boost controller
202.6rwkw. Hit 11psi 2300rpm, got to 12psi by 4500rpm for a bit and dropped to 10psi by redline....
turbo back exhaust
just jap fmic
boost controller
WTF????? is that all you got?? No aftermarket ECU?? That car must be running rich as hell.
your kidding thats awesome man!!!! Is that your R33 in the pic doing the monster burn out?? I was under the impression R33 ECU's were the cars weakest link and the first think that needed to go. keeping the stock ecu in your case is mad cause its protected well due to ecu's protection in regards to running rich. Is this common for a boosted R33 running 180-200rwkw to run on a stock ecu well like yours. Or is your R33 some kind of freak of nature!!!
Edited by LatinR33
yeah it was at the drags....put on some old stockies and sat there for a bit...
i dont know too much about whats normal, or much about r33 ecu's being new to the scene but it seems to be going good. again not sure what others are running with stock ecu...some guys said i should check if it has been modified or chipped....but i really dont know too much about it....just fiddled with boost controller to set it up and chuckedf it on....
Sounds to me your cars just a freak of nature cause I dont think the R33 ecu can be chipped or modded. Thats mad!! Some other guy here I just read got 188kw's on just an exhaust,fuel pump and power fc!!! thats nuts I know Dyno's figures arent exactly accurate but thats still alright :P Must go good regardless.
i had 195 with exhaust and intercooler on 10psi stock turbo. even have the airbox in there. it just happens. maybe its just cars from the south west lol. it was running very rich, but still made a reasonable power curve, with the exception of a massive hole at 6-7krpm. but still 195 lol.
since fitted exhaust cam gear, power fc and a few other jazz and with 12psi got 188 at the uas dyno day lol. put bosch 040 in the other day and will tune it again tomorow and see what i get, before fanging it on the skidpan on saturday :unsure:
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
    • Yeah, my offer was more to show exactly how rough and ready the rig can be and still be useful. Youtube vids will definitely show cleaner setups. Same concept though.
    • I would guess the seal has gone down at the speedo drive and gearbox oil has crept up the drive cable sheath and fouled the speedo head.
