Hi Guys,
Looking at getting a 95' R33 GTS-t's (in QLD) and was wondering when it comes to inspections is best to get someone like RACQ/NRMA or someone specialised in the area like someone who works in a perfomance workshop? Also what would the costs be roughly?
I dont know of any performance centers myself locally and because I live on the Sunshine Coast probably getting the car in a workshop would be a hassle?
Edit: I've only recently moved to QLD, is it compulsory in this state to get RWC/SC's when selling a vehicle?
Thanks
https://www.sau.com.au/forums/topic/16994-pre-purchase-inspections/
Yes, you need a Road Worthy Certificate for the sale of a car in Queensland - although they have just changed the name of it I believe (a beautiful example of bureaucracy at its best - same inspection with a differently named piece of paper at the end).
I personally would not put too much stock in the RACQ check over - get a mechanic you know (or at least one the seller does not know/use) to look over the car. Unless they specialise in the particular car you are buying I wouldnt see why they have to be a 'performance' shop.
really i got mind done with a guy from lube-mobile. Yeah $88 and he comes to u, this was in helensvale though. He did compression check, he didnt have to, but yeah he did it cuz I asked. Guess i just got a nice mechanic. Go LUBEmoBile! They r cheaper then NRMA check too, and they do roadworthys. THUMBS UP 2 THEM!
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
