Just making up some intercooler piping for a 450x300 core.
Anybody know a place to get cheap bends? Most places have to order in etc..
Making the piping up myself so have to get some silicon joiners and pipes. Also need some straight pipe. Going 2.5"
I'm just goign to use mild steel in case I need to weld. Will give the outside some coats of paint to minimise corrosion.
Cheers
Edited by benl1981
You think so?
I thought I would get mild steel so I can weld it if required and also to put the lips on.
With aluminium I cant really do that.
What sort of price is the Al?
I can get a 180 degree for $40 ..90 degree for $26 and $26 per metre. That is anodised mild steel.
What about silicon joiners - where are they cheaper?
Thanks
Theres a place out at Richmond that does them ! Buggered if I can remember their name though but I do remember they were bloody cheap though. About 12 bucks for 90 degree bends. Ive also seen them in Peps auto spares and i think they were about 20 odd bucks for a 90 !
They where mild steel bends. Was gonna go to Peps at Wetherill Park this arvo but ran out of time. I'll have a go in the morning and let you know. Glad to hear the gear knob is still good, how longs it been on now ?
P.S. got a carbon fiber center section prototype just about done, looks very hot .
Windsor exhaust in Richmond -- on Windsor St
also importers of Stainless piping
    • Hello, just just bought an 1999 enr34 with a stock rb25neo and I'm looking to upgrade the engine to 500whp I know some basic things but wondering if there are things I'll need to do to upgrade the stock block and all the bits and pieces to achieve this.
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 😅
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 🫠
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
