Check for a vacume leak like a leaking manifold gasket or intercooler pipes and all the vacume hoses even a small leak can cause problems. The easy way to check for a leak is to have the engine idling and spray engine start over all the hoses inlet manifold and intercooler pipes if there is a leak the engine will rev up or splutter when the engine start gets sucked in.
  • Replies 46
yeah going to chech that today, i have some pluming end caps to allow for plumming up of the air compressor and looking for leaks that way.
also founf on the net that the plug near the washer bottle can couse problems, so i am going to clean it up and redo the connection to make sure it's AOK.
other then that i am out of idea.
I did a log of the car this morning and noticed that as soon as it does this and goes funny, the oxygen sensor drops to zero and then bounces back then back to zero,
dropping to zero means really lean, ie could be fuel cut. what do injector duty cycle say as same point?
post up your consult logs would help
just cause the ecu is remapped doesnt mean its necessarily remapped "properly". a few stray values and the car might be cutting all fuel for given points in the map. can the rom be downloaded with consult? if so maybe u could check that out with some rom editor software and see if anything looks dodgy whereever you're having problems
I have the .bin file for it i will PM you with it. It definatly has not got boost cut on the ECU. Like i said teh ECU ran fine for about 6 months, no issues it was briliant, and somethign has gone wrong since then to make it liek it is.
I will do another log of the car tomorrow morning and post it up for you all to see.
I have had a new CAS and AFm on, no differance, new TP and ACC valve, no change, have 6 new injectors to chuck in it and do a full blown leak test on the piping.
did u get any fault codes? under 3500 rpm sounds like possibly a knock sensor issue
and im not up to speed on rom stuff, but if there is a secondary knock map, then maybe its detecting a bit of knock, and then using that knock map (which could have the dodgy value in it) or simply the knock protection is what ur feeling (r&r)
not sure if the ecu listens to knock sensor at idle though, so you may have another issue there.
well got a new ecu and no go still the same issue. I did a full log this morning and am about to go over it and have a look.
I was thinking Knock sensors to, but accoriding to my SAFC II no matter which one i connect to, thy both show simmilar values. I have a set to put on, so that is next on the line.
This may fixnumber two, but still starts like a dog in the morning.
As for fault codes, sweet FA.
This sort of sounds like what my car is doing atm. It's standard apart from a 3 inch straight through exhaust and a pod filter. It keeps stopping. Like if you drive along it will stop and then jerk back into life again. It doesn't seem to be related to anything. The only thing maybe is that when it is warm cos i don't remember it doing it while its been cold. I'm thinking it could be something to do with the ingnition because if it was coilpacks it would just miss wouldn't it?
Good luck with your problem WogsRus, hopefully your solution will help me :P
Cheers
Stricko
EDIT: Oh BTW i'm trying to get hold of an ECU Diagnostic tool to see what i can find. Will post the results.
Edited by stricko
yeah well still searching. I did a pressure test on all IC piping and connection, 50psi and holding no issues there. Still to pressure test the planum.
Getting a new PCV valve for the rocker just in case.
I had two more ecus and it's not that. Nothing to do with mapping, as i had my mates PFC and it still does it with that, and his can has same mods and power.
I have replaced 90% electrical componenets and still nothing. Going to go over teh wiring loom as there has to be something worong with it. HAS too.
boooohhooooo,
pretty sure 0 = lean, which means u have a fuel problem (rather than ignition...if fuel was getting in but no ign, o2 sensor would be rich)
had ur injectors tested/replaced at all? ran any additives etc?
u really need to post logs though...eg is the fuel problem because the ECU is telling the injectors not to inject, or because the injectors arent injecting the fuel (even though the ecu is telling them to)? eg is there an input sensor (afm, engine temp, cas etc) that is messing up at that rpm due to vibration etc, and the ecu is responding accordingly? cant tell without the logs.
i have an a stock reg and a 1:1 rising rate on inline as a precortion. I have the log i posted it here.
http://www.skylinesaustralia.com/forums/in...howtopic=170677
So far i have showed it to a couple of people and taking their instructions on board.
Cheers
Stricko
check or replace the CAS with a known good one and see if problem goes away.
Edited by URAS
Cheers
Stricko
Right i've had the ECU diagnostic tool plugged into my car and went for a drive. The CAS reading went up to about 6000rpm even though the engine speed wasn't this and the when it jerked back into life the CAS reading came back to normal. Getting a new CAS ASAP to hopefully fix my problem. The ECU diagnostic tool also said there was a AFM problem. Could this just be because of the CAS being dodgy or could my AFM need replacing as well?
BTW car is a 1993 R32 Skyline GTS-T Type M with 86000kms, 3inch straight through exhaust and pod filter.
Cheers
Stricko
Edited by stricko
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
