could possibly have AFM problem - id replace the CAS first though, particularly if ur AFM readings were ok/not spiking etc.
then clear fault codes and see if afm code returns
  • Replies 46
I'll give that ago after i've got the new CAS in. I didn't notice anything out of the ordinary with the AFM readings so hopefully the fault code won't come back. If it does then i might have to fast track my Z32 AFM purchase :thumbsup: Thanks for everyones help, especially because it is in someone else's topic! Sorry WogsRus!!!
Cheers
Stricko
Hay guys, i think it might be my stock fuel pressure reg.
Ages ago, when i got the aftermarket malpasi one, for some reason i could not run just the malpasi one, it would exibit thesame issues as it does at the moment, surging ect.
The solution was to install the stock one in series with the malpasi one and the symptoms disapeared. SOOO it looks like i might need to get a new one to test.
HOWEVER the car starts great now, no idea what happend. LOL.
WELLLLLLL
it's not the fuel reg at all, tried one of a running car, BUGGGAA, back to the drawing board.
I wander if it is possible for my cam belt to slip a toth, i swear that last night i herd it backfire through the intake, is that possible and if so what would couse this.
The car is bad, it's basicaly stops between 2500-3500 rpm on boost.
Going to do more logs this afternoon on the way home.
Any more ideas guys.
    • Yep that's a superb price and ther is no way you will over capitalise on you investment.  As to the bracket, again just use the passenger side seat  bracket ( obviously reversed ) as a sample to reshape it and in this case, TIG it back together.
    • Thanks for that.... If only I could do something once and be happy with that, like some people do....
    • I had no transmission at all so I managed to find a big box manual gearbox from an R34 GTT for an insanely good price in EU. I converted it to push type which cost more than the transmission almost, with parts from Amayama! These engines are very strong and can put out decent power with a properly sized turbo. You can save on money from parts like pistons and rods, and invest those in the transmission and other parts. I suggest you join the RB20 Enthusiasts facebook group, plenty of info and almost daily posts there about 20DE/DET/Neo+T builds. (I hope I'm not breaking any forum rules by mentioning third party platforms, just trying to help the buddy out)
    • Yeah, having tried all of those methods including BBQ+recipro/hacksaw, I ended up buying a bush press kit under $150 that works well, like this: https://www.ebay.com.au/itm/355967727167?mkcid=16&mkevt=1&mkrid=705-154756-20017-0&ssspo=sfmmuhxgqhm&sssrc=2047675&ssuid=dJvnaZ11TB-&widget_ver=artemis&media=COPY It basically has a range of pushers and cups with threaded rods between to press out a range of large bushes. The problem with any sawing solution is minimising damage to the subframe side, although it probably needs a quick sand afterwards no matter what solution you try due to damage
    • Hi. Thanks for the answer. I do not have instagram 😄 I too considering turbo the RB20DE NEO 🙂 But i think i upgrade the gearbox first or at least buy new.
