I have this little problem with my 33 gtr where i get intermittent loss of power. Its stock standard not even an exhaust.
This is what i have discovered so far,
When i first start the car in the morning when its cold, it seems to be lacking a bit of response, but i dont push it, it just feels that way down at the low revs. Maybe thats what its meant to be.
Once the water temp gauge goes up to where it should be, the car feels good! the response and power is how it should be. But SOMETIMES after driving for a while like 30 mins plus, sitting in traffic here and there and when the oil temps are up to about 80C it feels like it is a bit hesitant to go at lower revs and it feels slower through the rev range too. Almost feels like it doesnt want to go for a second or so and then slowly the power comes on.
But then when i turn the car off for a while, come back after 20 mins drive it again and it feels like normal again, pulls hard and all. WHat the hell is going on?????? Can sometime tell me what it could be? Ignition timing hasnt been touched, plugs are correct too.
https://www.sau.com.au/forums/topic/169970-strange-problem-with-gtr/
Its running the stock air box with a hks panel filter.
And the boost seems to be normal, it just doesnt want to pull as hard. Under say half throttle in 2nd gear around 2-4krpm it feels flat and laggy. But then i stop to get petrol, start it up a few mins later, its feels much better again.
My mech plugged it into a diagnostics thing and reckons ignition timing is ok. he also reckons the coils and sparkies are fine and he reckons the afm is ok too. He is kinda stumped too, but I havent realy been able to show him the problem properly as it is intermittent. He reckons it drives fine because he hasnt experienced the changes in performance.
He was suggesting a possible fuel pump problem?? could it be possible?
It sound like the ecu is seeing knock and then using the low octane ignition map to protect the engine. Turning off and on allows the hi octane map to be used.
I had a similiar problem on GTSt, it was detecting knock just off idle when at operating temp, try retarding the timing 2-3 degrees at the CAS.
I have a similar problem except mine's in a 32 Gtst with a RB26 convertion. At low rev's specialy in 1st and 2nd gear.
I go to take off and its like the turbos are straved or something, it will slowly boost up then drop out.
But if I take off on high revs, its fine.
Can't think of what the hell it could be.
My car has the same problem from the sounds of it. I'm running 1 bar boost (restrictor removed from standard setup) and all your standard mods. For me, the car drives perfectly for the first 10 mins or so, making 14psi or so. Then it hesitates for half a sec, becomes sluggish and will only boost to 7 psi, but it feels flatter than when the car was running that boost standard.
I can then turn off the car, restart it instantly and its nice and responsive again, making 1 bar again. It clearly electrical but i get no warning light on the dash to say somethings wrong and i cant figure it out. I figured either afm's or my boost solenoid? Sounds very similar to your dramas, probably the same item giving us greif.
Not sure what's going on there Phil.
I have never experienced that problem in mine.
In regards to driving it first thing in the morning when its cold, mine is very spluttery if it goes over 3k rpm. But as soon as its mildly warm its fine for the rest of the run (whether its a 5min or 5hr drive).
Hope you can find the problem, fix it and let us know for future reference!!
- Dave.
- Dave.
Exactly the same things happens to mine when its cold. As soon as you hit abit of positive pressure it starts to splutter but when its up2 normal driving temp its fine.
That's normal for the stock ECU, mine used to be like that when it was cold in the morning, as soon as the water temp hits (can't remember) it switches from open to closed (or is it the other way around) mode... and it runs good/normal. When i switched to a PFC i don't have this anymore - but not like i fang it when cold anyway, so it makes no difference.
As for driving it for 30mins and then it dropping boost from 14 to 7, there is something wrong there.
Recently in the colder temps i noticed it is happening more often like in the mornings and nights when its like 5 degrees or so. Warmer days seem to be ok asnd doesnt happen as much.
Strange thing is, it doesnt do it when i thrash it, it seems to happen under low revs and low boost etc, low throttle. Sometimes I give it the fang up to 14psi and its fine still. I also disconnected the boost solenoid so it runs 7psi but still does it. So its not a high boost issue. Something to do with too much air flow, but why? grrr
I have a PFC coming to im going to throw it on the dyno to see whats going on and hopefully fix it or at leats know what to fix.
  • 5 months later...
I recently replaced my r32 gtr afm's with r 33 gtr afm's and since then it has been messing up at low rev's as well, same business, unless i give it to it (which i won't because it's cold) it feels damn slow and damn laggy.
Once it heats up it's all fine though
I regapped my plugs from 1.0 to .8 at the same time i put the new afm in, im gonna try re-gap my plugs to 1.0 again tonight and see if it makes a diff
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
