Thanks brad,
I'll give martins a go on the lucas gear as i am working 10minutes from there atm so it's easy to drop in at lunch time. If i have no joy there i'll give you a ring.
Chris,
more boost :laugh:
If the ultimates are doing the job id suggest you really aren't working the brakes very hard (thats not a bad thing). I rate them quite highly as a street pad (because i don't care about dust) but it doesn't take much to overheat them.
I'm generally a bit reluctant to recommend the HC+ pads as they go for $250 plus per end (mine actually cost me $310 a couple of years ago) which is a pretty big outlay for brake pads. But they work lap after lap, the rotors aren't wearing, the pads are barely wearing, and i don't get shudder or any other annoying brake problems. I really can't fault them as a street/track pad other than to say their cold performance isn't great.
Dave and Brad,
Cheers for the replies guys!!
Yeah Brad I may try and make south cct on the 20th and we'll try those heat thingies! :wave: I think I might go another set of the ultimates and get more practice with my braking - then upgrade (yeah brake dust doesnt worry me one bit!)
Dave - hahah yeah Im still learning this track day thing mate - I get more confident each day and at the last autsports day I relised that I was "soft" on my braking and reslied I could have braked futher into it!
front project Mu HC+ 6 track days and counting still around 50% pad left. Out brake anything of similar weight (except a mate with a sil80 and the same pads). Still can't fault them.
Dave, just been reading back - where do you get these pads from? And how much?
Cheers!
I got mine from mu secret years ago for $310
These days it's cheap and easy to get them in from japan. Nengun list them for $245 delivered but if you want them quick id suggest talking to one of the many private importers around.
My serious suggestion, buy both and try them back to back!
The only way to get what you want from the brakes is to try different combinations.
If you want the Lucas' pads let me know. ABS have them at the cheapest price I can possibly find.
Edited by Risking
what is ABS phone number?
Depends which one, they're a franchise. ABS I've found are OK on prices, when we've been out of stock of something and a customer needed it urgently I've run down to ABS to get it and then just pass it on at cost. We're on just about the best trade price ABS will offer, but most of the time their prices don't worry ours.
Lucas (now called TRW) can be bought from any parts outlet that has an account with ATAP.
Paying some of the prices quoted in the $100's for brake pads seems ridiculous, are they platinum or something? Still I guess if people keep paying then they will keep selling at those ripoff sort of prices.
define ripoff.
If a $300 set of pads lasted 3 track days, yep, rip off. If they last 6 days, thats 50 a day, they are starting to look pretty good, If they are 6 days in and still have 50% left on them would you still class them as a rip off?
I've actually spent more on cheap rear pads in those 6 days than i have on the one set of fronts. And by cheap, one set was $130 and lasted a day (actually 5 20 minute sessions, 2 of which were wet)
Still think they are a rip off? I think my $300+ fronts were worth every cent.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
