I'm in need of yet another set of pads for my r32 Gtr streeter / toy
Currently run project mu "club spec" pads on r34 gtt rda rotors
The pads perform well, and are reasonably behaved on the street. Obviously more rewarding once warmed up. . .
Looking for something with similar performance that might last a bit longer, these are only lasting a few trips to mallala until they get unpredictable and they break up.
Not interested in a big brake upgrade, prefer to keep having fun in my stock r32 thanks
Can anyone recommend some pads that will provide similar performance and possibly more life for a reasonable price, otherwise I'll keep throwing P'mu's at it.
Hey guys and girls.
Just wanted to give some initial feedback to my bendix street, race, track pads.
Put them on with some dba 4000 rotors, and they seem ok.
Good initial bite when cold(after a bed in period).
But so far seem very dusty.
Could be the slotted rotors, but I now have a nice brownish/red layer of dust on my front wheel.
Tears are running firehawk(i know I know) and don't seem anywhere near as dusty.
I am getting squeal from either front or rear.
Schamffered all pads, went away for a while.
Might have to do it again.
Ok, that's my little rant, will keep updating as I start to use them more after my engine rebuild.
So should I have believed the Bendix rep when he told me that they have resolved the brake dust issue with the new SRT's ???
Also going to be using them all round with Kangaroo paw DBA4000's
Guess i will see.
Has anyone tried the new Ferodo DS Uno pads on track? I had them recommended by one of the larger race brake suppliers in the country, and apparently everyone 'raves' about them.
Has anyone used them and are they worth raving about? Any feedback on durability, disc life, modulation, etc.?
Alternative is Pagid RS14 / RS29 for similar price.
Thanks
Jack
Bump
  • 4 weeks later...
been using DS2500'S for around 5,000kms now, including 3 trackdays. still look brand new. no fade whatsoever and as much i can tell they are very rotor friendly.i have a spare brand new set for sale if anyones keen.
whoa....ok after 21 pages of reading , and after wiping the blood from my eyes....the general consensus for a ONLY STREET driven skyline r33 gtst that gives
- low /minimal dust wear
- good quality
- easy on rotors
- low/minimal noise
-excellent cold bite
-not much fade(not that youd worry about that type of thing for street anyway)
and the winner is......
QFM HPX?
Would everyone agree?
Have Resmas myself. Have not had them long enough to get a complete view of them but I am quite impressed so far. Best thing is no noise exept maybe an cold morning/evening the very first time you brake.
Used the HPX on my wrx before with similar results, though it always ended up slightly squealing under light braking.
Ok so fitted RDA slotted rotors all round with QFM HPX pads. They stop on a dime , except when they warm up they squeal like CRAZY. To the point where its almost unbearable and embarrassing. Hardly any dust and good bite when cold , but the sheer loudness of the squeal when warm is enough for me to not purchase these pads next time....
+1. I fitted myself QFM HPX with new RDA rotors on the fronts about a year ago - no problems. Got workshop to put rears on with new rotors about 8 months ago and have had this exact problem which has gotten worse over time. It's LOUD and very annoying, going to change the rears before summer hits (does it straight away if its a hot day)
Edited by Dani Boi
frankly is quite annoying that I now have to hold myself back from braking hard or the unbearable squeaking starts....which defies the purpose of choosing these over stock anyway. I'm annoyed that I was told its a street pad , yet sounds extremely un streetable to me. I would of preferred that gsl rally let me know this when i purchased it as I asked for their recommendation. I asked them about the a1rm and how streetable it would be , they suggested the hpx since they are low noise :yucky: and low dust. Not happy as the problem sounds like its getting worse.
rolling to a stop at traffic lights while every person in a 5km radius turns to look at you FTL
Don't be so quick to throw the baby out with the bathwater... Thousands of people (literally) run the HPX with no issues, unfortunately opposed piston calipers are ALOT more succeptable to noise, and so are alot more sensitive to small things like incorect fitting (ie not lubbing the caliper pins) or incorrect bedding in (ie. getting them too hot during bed in, very common post asbestos being banned).
I would recommend this:
- Take the pads out, give them a rub on some smooth concrete to freshen them up.
- Switch the pads left to right caliper, so the rotor is turning the other direction on them.
- Follow QFM's bed in procedure:
http://qfm.com.au/userfiles/files/BEDDING-IN-PROCEDURE.pdf
I've got the HPX on my Subaru, which uses the EXACT same sumitomo caliper Skylines are fitted with and they're dead quiet.
Alternatively PMu make a shim kit but they're faily expensive, or else we can send you the universal stick on shim kits for nothing to try. They generally work pretty well.
Any questions at all feel free to give us a call, 1300 884 836.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
