Thanks for the advice mate. What about Ferodo DS pads? Would they be any kinder?
As far as I know, Bendix do make pads for the skyline. Might get a set just as a back-up if the HPX's dont shut up.
I think your better off working with the HPX. They aren't a squeaky pad. I run them in the daily, and they don't make a peep.
Take them out, clean up all surfaces and give them a rub. Clean shims, and calipers. Then give the bedding in procedure another go.
Thanks Guys. I took out the pads and gave them a file down (see pic of what I found when I took them out). After a quick drive the squeal is still present (very very minor). Will keep alert for the next few days...
If you think the squeal on QFMs are bad? Don't go Bendix...
  • Like 1
Okay guys, just reporting back. The squeal is back and its worse then ever. Sudden hard braking makes it worse. Attached is pic of my rotors when i got home. Will now bin these pads because Im just bloody tired now. What is the best pad for the street? (price doesnt matter)
I'm using Bendix HD on my daily R33 and have only heard one little peep first thing on a really cold morning coming down the slope of my driveway.
Have RDA Dimple drilled & slotted discs. Quite happy with them as nowhere near as dusty as I was expecting.
  • Like 1
Get some Intima pads, if you're not hitting the track just go Intima SS
I'm using Intima SR, ZERO squeal.. however they do eat rotors as they are more aggressive, the SS ones should do the trick...
here they are:
http://www.intima.net.au/ss_pads.php
  • Like 1
I had bad brake squeal with the QFM pads I have, I think they are QFM ARM1's
Anyhow, I popped them out and rounded the edges with a file, rather than a chamfer.I did the trailing and leading edges, and it seems to have done the trick. I should have taken some pictures, but its around a 5mm radius.
I only did the rears, as that seemed to be the main source of the noise, but I'll do the fronts next time the rims come off. I didn't really want to change pads, as they perform really well. Prior to rounding the edges, I'd get squeal from around 40kmhr down to a complete stop.
Thumbs up the the QFM pads, and now they are quiet, I'm very happy
Well I get my opens soon so I'll FINALLY be able to drive my 32 legally :)
I have stock brakes & rotors as far as I know and I'm wondering what pads I should go next as I'm pretty sure they're on their last legs
Car will only ever be street driven.
Was thinking MU or QFM. Mainly because they are the only ones I've really herd of.
A point in the right direction would be great.
P.s. car is 32 gtst type M
QFM (my experience)
Good street stopping power on the track, however once they give up they give up, noisy (hectic race car noise) and cheap (my experience)
Intima SR (my experience)
Good stopping power, a little less bite than other pads, will not fade on wakefield with my boat, even after 7 hot laps, quiet, seems to chew rotors & cheap
Bendix Ultimates (my experience)
Big croc of shit, faded after 3 laps of Eastern Creek South circuit. Might as well install drum brakes all round. Noisy, loads of dust, chews rotors.. price wise no idea came with my car.
Project MU HC+ (mate's experience)
Great pad, not too noisy, terrible when dead cold however hold up well on the track - expensive
QFM (my experience)
Sweet man, thanks for that. Looks like QFM for me.
Uhh a really stupid question but when you say "crap when cold", obviously you need to heat them up.. Just by braking more?? :/
Never a stupid question :)
Yes a few jabs of the brake gets them warm. The Intima SR pads are rated from 0 to 700 degrees, however I do find they need a tiny bit of heat to work, the QFM A1RM however don't need that heat and bite when hold.
I find that the QFM A1RM has better bite/feel than the Intima SR, however the QFM squeal like a bush pig and do give up after consecutive hot laps, but for street driving you will NEVER experience any fade.
  • Like 1
Cheers again mate. :)
So the QFM A1RM constantly squeal? Or mainly on track, or just when there's no more pad left?
I don't mind a squeal, quite funny watching people move forward when I'm slowing down behind them :P
Pretty sure I'm going the a1rm's. :)
  • 4 weeks later...
Has anyone used QFM Comp 9?
I need pads front/rear for my car (R33 GTS-T calipers).
I was looking at PMu HC+ front and the D1 Spec rear, but it's more money than I would like to spend.
Car is my daily, but with drift days and fun circuit days.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
