hey i have a r32 approx 260rwkw using for hillclimb/sprints and bit of track im thinking of running r33gtr 324mm rotors with caliper spacers, A1RM pads on the front matched with dba4000 slotted rotors and penrite sin race brake fluid the question is what is a good combo for the rear? do i require slotted rotors along with another set of A1RM pads or would hpx's do the job?
cheers
Edited by freestyleMX
I posted that in june 2009 - after I had given up on the A1RM's - don't buy them if you can't stand extreme noise! - and had swapped to the bendix heavy duty. A week or so ago they wore out, so I got almost 3 years of driving around town with them on which isn't any where near as good as the original ones.
Needed another pad in a hurry, so put the a1m in that where sitting in the shelf. Lasted in 3 days as I'd forgotten how bad they were for noise! I even tried the anti noise spray etc etc, before giving up on them yet again...
While I was down at repco buying something else, I mentioned I was looking at some new pads and the guy said they do repco branded ones for the skyline now, which are super quite with integrated shims. Given I was buying a few other things he did them for $70 (for the front two pairs) so I thought, what the heck, worth trying.
I've been pleasantly surprised - dead quite, reasonably good feel - but remember I'm not doing track (or anything like it!) I'm just driving around town... If you want a straight replacement when the standard ones where out, I don't think it is a bad choice...
Ian
ps PM me if you want a pair of not very used front A1RM's for a r34 gtt for a cheap price, as they are never going in again... :-)
I would strongly disagree about the pad noise. I have been driving with A1RMs on the front brakes with my s14 for about 10months. I drive at least 3 times per week, if not daily. I only experience braking squeal rarely when pulling up. Overall, brake squeal isn't as issue with this pad. I will conceed pad dust is a major factor but probably a lot more noticable on white rims. Cold performance is hard to tell since my tyres also have trouble in the cold, so cant really tell. though i suspect having both susceptible to the cold doesn't help.
Unfortunately HPXs don't last on the track, even on the rears. I thought I could get away with them but after two days at Phillip Isand and 3 months of semi-regular daily driving, they are already gone.
Will be switching back to the A1RMs when I have the time to change them. ( Still using A1RMs on the front. )
just tried a set of QFM A1RMs in my r32 gtr for a club day on the weekend, they weren't at all noisy and worked well but they are around 2/3 worn out after just one day? i would of liked to get a couple of days out of a set of pads or am i asking too much?
Pads start wearing that quickly when they get too hot. Use a higher heat rated pad and you will get a few track days out of one set.
I have been using Hawk DTC-60 on front of my GTS-T and HT-10 on the rear for a while now. They wear slowly, never really fade and work from cold but they are designed as a track only pad.. really bad dust, noise etc. You can get them cheap from http://www.hawkpadsdirect.com/ so for the money i think they are hard to beat. Only thing is they are super super aggressive so take some getting used to. Personally I would suggest a pad thats easier to modulate (they will generally say something like "less initial bite") esp if you arent used to really high friction pads.
If you dont mind spending more $$ then some of the project mu or endless track only pads would be my first choice.
dont rule out the QFM comp pads, ie Comp 9 and comp 2 etc. A1RM's on a GTR at symmons is a fairly big ask, especially if its standard weight with standed size rotors etc.
Has anyone tried the new Ferodo DS Uno pads on track? I had them recommended by one of the larger race brake suppliers in the country, and apparently everyone 'raves' about them.
Has anyone used them and are they worth raving about? Any feedback on durability, disc life, modulation, etc.?
Alternative is Pagid RS14 / RS29 for similar price.
Thanks
Jack
Edited by 4Pot
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
