I know this has already been a topic for discussion but I need to know if there is anyone in south east QLD who can hook me up with an engineer who will mod plate my R33's front mount intercooler modification - the chassis rails are NOT cut but the front bumper reinforcement (Reo or crash bar) has been cut to accomodate the intercooler.
The officer did not notice the hole cut just under the window washer bottle for the piping - nor did he listen to my story about how I purchased the car 5 years ago with the front mount modifications (but no intercooler) already in place.
I know this is going to cost $ but I just need someone who can look over it and certify it.
...surely the front mount in place 'puts back' what ever crash/crumple zone was taken away with the reo mods?????
depending on what dollars you have to spend you have a few options:
To do it properly you should really get a new bumper and change the intercooler set-up so you dont have to cut into the bar
but if you dont want to spend bulk coin and....
if it was me i would either try and find an engineer that will sign off on it or (and this is most likely what i would do)
go to a wrecker, offer them a carton of piss to borrow one of their stock front bars and install it. Its not hard to take the bumper off and i would take the intercooler out and out a straight piece of pipe in its place so you can still drive it. Sounds dodge but as long as you dont boot the crap out of the car it will be ok. Take it to the pits, get it passed and change everthing back after and then your done, until next time...
Off topic but do you live on Karbunya St behind Chamonix?
reo cut = big trouble. An intercooler will do nothing compared to a reo and hence why it is completely illegal to remove/cut it. As others have said you'll have a hard time finding someone to mod plate it unless they are very dodgy!
Yes you will most probably have to have to get the reo rewelded ( or find another one) and change your intercooler set up
Mate i would be finding out who originally wrote out the roadworthy certificate before you purchased the car.
Because if they passed it the way it is they might know someone who can give you a mod plate or they just did the big dodgey on you.
it's far from impossible, nearly every decent workshop makes custom mounts for coolers to ensure the reo isn't cut. Then again, its hard to get caught as people rarely check behind a front bar to ensure the reo isn't cut, so thats why most "kits" etc require reo cutting.
just a note about this.. the local bodykit builder here said that you can legally cut the front reo bar in the r33 as it can be bolted on and off the car and is not considered part of the chassis, however i would recommend against it as i modified the reo bar in order to fit on an aftermarket bumper.. last week i had a little accident where i barely hit the back of another car.. the other car is completely fine and my skyline is pretty messed up needing 5k worth of repair on it..
i can only think of one reason why it caused so much damage.. the reo bar was cut! so im sticking to a stock front bumper after the repair work..
Thanks all for your replys - I should have also mentioned the car has just been fitted out with a full body kit (and $8k re-spray...) which includes a Trust front bar that required cutting small amount off the reo - I say a small amount because the reo had already been cut by previous owner in Japan. I purchased the car 5 years ago from a Brisbane 'street machines' dealer (Brisbane locals will know who I'm talking about...) and they (or the previous owner) had re-fitted the standard intercooler back on - presumably for compliance, but then how did it get complied with the cut reo if I've just been defected for it... I'll tell ya how - dodgyness.
I'm all up for dodgyness in this case and I'm not concerned about the crash damage potential - I just want someone to hook me up with someone who'll give me the required paperwork to get this sorted.
Give AJM motorsport a call, they might hook you up.
There dodgey.
friggen hell must u contradict everything i say..?
so tell me about this decent workshop that doesnt cut a cooler..? supply a hybrid kit to a shop and i put money down they will cut it.. :P
I dunno, are you ever right? Reference case and point the sr20 thread you've been pwned in. Plus its entertaining stirring you up!
First of all I dont think anyone cuts the cooler...we're talking about the reo.
And the workshops cut it because the "kit" doesn't supply correct mounts, as I said...workshops such as millenium (and many others) will make new brackets or tell you of the risk. You said its impossible to get a cooler to fit without cutting the reo..this is blatantly incorrect...all it requires (in most cases) is new brackets...most people buy hybrid kits and are to cheap to spend money on new brackets. Then again, as I said, you rarely get caught...so why bother.
Why is it then even with big name brand kits, ARC, Blitz you have to cut the reo bar?
One would think they are trying to do things the right way and it's impossible to not cut the reo on some model cars?
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
