Hey guys,
Was late for an appointment today and was speeding a bit near home (with an IS300 on my tail). Saw a cop car facing me and hit the brakes. He turned around and pulled us both over. Got me at 72 in a 50 zone. I told him I have a clean record and he said once it's logged he can't cancel it so I should write to them and they might consider it as I'm 21 and have had no offences whatsoever. The cop was okay about it but said unfortunately he couldn't do anything about it there. I acknowledge my mistake and understand that it's my own fault but hope to appeal with my clean record.
What do you guys suggest I do? (or use in my argument). 3 points and $197 for a silly mistake is not good in anybody's language :D
Anyway, just thought I'd get your opinions. Thanks in advance for any comments or suggestions.
Cheers
https://www.sau.com.au/forums/topic/17001-speeding-ticket/
  • Replies 40
Yeah he probably didn't want to bother. He suggested I write in though (maybe to sound like he was trying to help). The infringements people said I can try my luck and write in using my clean record to gain a 'caution' so I'll see if I can come up with a letter and some kinda excuse.
Hehe yeah the 10th one would be a little more distressing, but you know how it is, it's disappointing losing your clean record to a silly mistake.
https://www.sau.com.au/forums/topic/17001-speeding-ticket/#findComment-351708
I have tried writing in but it did me no good. If you acknowlege you were in the wrong then you have nothing to write in about... I suppose I have this attitude because I have 12 points back now and am loving it.
I know EXACTLY how you feel in regards to this ticket, but it is the only way we all learn!
https://www.sau.com.au/forums/topic/17001-speeding-ticket/#findComment-351905
I agree with everyone in that there's always a first offence and tojust cop it on the chin, after all it was my fault. You do have a point there in that I haven't been driving for that long anyhow.
Btw, I normally do leave early but I guess there's always a first hey? So anyway, it's all over with now so I'll accept it as it is.
Thanks for all the comments.
https://www.sau.com.au/forums/topic/17001-speeding-ticket/#findComment-352226
Yeah I bought it just after finishing uni (a few months ago), I bought it used and on a loan with a residual so doesn't work out to be that expensive. Would've cost me a similar amount for an R33 GTST since the bank wouldn't give me a residual on one of those as it's imported.
https://www.sau.com.au/forums/topic/17001-speeding-ticket/#findComment-352882
Originally posted by Mick Trainer
See what you can do but I would not put the house on it.  However for the record it is garbage that he cannot do anything about it once it is logged.  He just didn't want too.
Mick.
exactly.
he's probably saying that so he doesn't look like a pri*k or something.
they are trying to pin me and he didn't even HAVE a radar thingy. :D
https://www.sau.com.au/forums/topic/17001-speeding-ticket/#findComment-353167
    • I'm selling my personal race car. 1992 BNR32 Skyline GT-R About eight years ago the engine developed the dreaded low oil pressure problem. I removed it and found the issue. However shortly after I moved half way across the country, moved my work shop, bought a house, got married, then moved my shop again to it's permanent location for the time being. in turn I do not have the time to race this car as it should be. In turn the engine I built for this car will end up in my street car and this car I hope finds a home with someone who can use it to it's full potential. The roll bar was built by Jason Noren Fabricaiton in Pomona California to SCCA and NASA Specs. The car used to compete in redline time attack and global time attack enthusiast class. It also has a fire suppression system.  The car is with me at my workshop in Kyle Texas, USA. Shipping it is no problem, I can personally deliver the car to the port of either Houston or Los Angeles. Any other port depending on where it is may require transport but we can always work that out.   The chassis itself is rust free, rear quarters and under fenders are free of any rust so it's a very solid foundation for anyone who wishes to move forward with it. As posted and at the asking price of $20,000 USD the car includes all of the following;   All OEM Body panels, front fenders, rear bumpers etc.  OEM Nissan Projector headlamps (Pictured N1 lamps were removed) OEM Nismo Side Skirts / Extensions OEM Rear Spats  Front & Rear Subframes are installed car is full roller Rear Subframe has Cusco Camber Arms, Whiteline HICAS Elimination Front Subframe has Whiteline tension rods and whiteline Sway bars w/ endlinks.  Buddy Club N1 Coilovers All chassis wiring and engine wiring is in tact. Attessa System is fully in tact and was functional before engine removal.  BCNR33 GT-R Brembo Brakes F+R with Endless MX72 Plus Pads, DBA Rotors & Stainless Steel Brake lines Billion Racing Radiator Billion Radiator Hoses Fluidyne Engine Oil Cooler Accusump System (trunk Mounted) 5 Speed Transmission w/ Transfer Case F+R Prop-shafts Rear Differential With rear Axles.  Nismo Gauge Cluster Nismo Clutch + Flywheel   Essentially what is needed to make this car running and driving again is as follows: A working Engine, an ECU, and time to put it together. The price posted is or best offer as I am willing to remove some components to accommodate price to a certain extent. If any serious buyer wants full detailed pictures, videos, or any questions I'll be happy to answer them. I believe this car is priced to move quickly considering it's a rust free and very straight chassis but always open to fair negotiation.  I can be contacted via phone or email. (+19517081648) email is juan@bardabe.com
    • So...to my (and my mechanics doing the swap) surprise...the oil pan from NEO engine does not fit 100% and needs to by modified like this: It is not a huge problem but in the future i want a "proper" oil pan. So question is...what different oil pan can i get to fit without any problems and modification? Thanks!
    • Some more info I found.  These are the last entries Yoshikiyo Fujii made on his blog before he passed away in 2009: http://blog.livedoor.jp/fujii_dynamics/ And finally this is where the workshop was situated:  https://maps.app.goo.gl/HhTPtHzt3WVcBTiEA
    • shit boxes, kids, and daily drivers are all welcome
    • Cam seals go hard. It's a very old car.
