I'm assuming you DO want more top end power than the stock turbo??
because you wont beat the stock turbo for response. :/
other options like a highflow rb25 turbo (ie. GCG) might be the way to go, steel wheels etc. and similar response to stock...
but in short, Nissan lightened the stock turbo by using plastic/nylon and ceramic components. It means it wont last as long and cant take much boost (1 bar is enough to kill it very quickly) but if the car is left stock and not thrashed it would probably suit it just fine.
If you want more power than the stock turbo can give you, there will likely be some compromises and one of those will be slightly less response/more lag.
You can still keep turbo lag pretty close to stock however...just not exactly the same ;)
gcg is garret is it not? correct me if im wrong thats just what i thougth it was. but dnt for get slideingperformance on these forums he does highflows for like 1200ish i think.
garrett an gcg are to different companies,garrett does there hi-flow for about $2200,gcg does there's for about $1700,garrett has a lot better/stronger components in side there turbo,i did a little custom work for garrett in december,
HKS GT2530 for the win. :ermm: Blistering response, I think it would be just the same as stock turbo if not better. But it does run out of air up top, I think from research it dies from ~-5500rpm, but that saves you having to go to redline all the time.
Just for an opinion, I just installed a GT-RS and running on just the HKS actuator I can't tell a difference between the stock turbo with tuned EBC and the GTRS in terms of lag.
So what is actually stronger? Because to me that sounds like a pretty incorrect statement
The GCG uses:
Garrett cartridge
Garrett wheels
Factory machined housings
The Garrett item uses
Garrett cartridge
Garrett wheels
So what parts are actually left that are different? None.
That to me suggests they are (component wise) the same thing.
Ignoring the actual spec of the turbos which is irrelevant when we talk strength of components.
The TD05 is a bitch to fit, but for what its worth - its a fair bit better than the stock R33 turbo.
A mate of mine runs a TD05 16G from an EVO 3 on his RB20DET. It DOESN'T spin the "wrong" way, has a single pulse turbine housing, spools about the same on the RB20 as R33 turbos spool on RB20s - but flows an absolute crapload better up high. It hit ~200rwkw without trying too hard....
They run a much larger turbine wheel than R33 turbos, and a slightly bigger compressor wheel - I'd say they'd have to be easily comparable with an HKS GT2530 in terms of power and spool.
It should be the same as a GT2835 with the .48 A/R in terms of power if it's from an EVO 3
  • 2 years later...
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
