i'm looking to change the steering wheel in my R33 to an aftermarket item with a quick release hub. Has anyone ever pulled a wheel off with that was fitted with an airbag? i'm just not sure how to go about it.
Dave (Rhinorebel) you've changed yours haven't you?
Disconnect your battery first. Need to remove the airbag second. On the side of the steering wheel is 3 plastic covers. Remove them. You now can get to the plug for the airbag and 2 bolts, one on each side. You will need to undo the bolts with a special star drive (I think it is a T50) Once the bolts are removed tha airbag will come out. Then simply remove the steering wheel like any other by removing the nut on the steering column shaft and pull the wheel off.
