clean with a wire brush and then use metho to clean off any residual dust. it shoudl stick then but at the same time, if there was any trace of water in the spray can when it was manufacteured it would bead up to.
try some brake and parts cleaner from an auto store
... that sounds like a good idea.
When I did mine, i used a wire brush and detergent, and scrubbed for a long time. That worked ok.
If i was to do them again, i'd try some brake cleaner, wire brush, and then finish up with some Prepsol/Wax&Grease remover.
Read the paint can to see if a primer is needed.
With the Duplicolour stuff, i used a Duplicolor metallic primer.
Edited by Trav33
you also more than likely have built up residue from tyre shine stuff over time which does not mix well with paint, I sand blasted mine which is overkill but I had them apart at the time. just give them a super good clean and you will be fine
Morning all,
I had my wheels off recently to paint the calippers on my car. I bought the proper calipper spray but when i sprayed it on it beaded and wouldnt stick. Do i need to prime the caliper or something????
Cheers!adam
As said you need to do more prep work before applying paint, have a look at Paul's DIY thread :O
i just did mine yesterday..came up perfect..
just clean the shit outta ur calipers..
<a href="http://imageshack.us"><img src="http://img518.imageshack.us/img518/9396/calipers001tx8.jpg" border="0" alt="Image Hosted by ImageShack.us" /></a>
<a href="http://imageshack.us"><img src="http://img300.imageshack.us/img300/1608/calipers002uc9.jpg" border="0" alt="Image Hosted by ImageShack.us" /></a>
<a href="http://imageshack.us"><img src="http://img513.imageshack.us/img513/6906/calipers003hb3.jpg" border="0" alt="Image Hosted by ImageShack.us" /></a>
    • Interesting....can't say I've ever checked it, have always just changed it in the off season as practice
    • Just checking, when we are talking about high temp fluid, are we all referring to DOT 5.1? I haven't had any issues with changing it every 2-3 years.
    • Yeah that is still true AFAIK.....good brake fluid should be changed annually because it absorbs water faster which is more often than most mechanics would do it. There are cheap tools that check water% in brake fluid if you all scientific about it. I for sure would (do) run good brake fluid in anything that even casually saw the track like Murray said; avoiding the risk of "exciting" fade is worth it
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
