There is a buyers guide Stickyed up the top I think.
My tip... look out for rust behind the door mirrors.
what is your petrol economy like how many l/100km i am going to be driving it every day to run a mobile service
https://www.sau.com.au/forums/topic/170136-buying-a-stagea/#findComment-3143836
Use the SEARCH button. I have and this is what i've come across.
Driven carefully i.e. off boost most of the time with engine running well-
Around town 14-15l/100km
Highway 10-11l/100km
https://www.sau.com.au/forums/topic/170136-buying-a-stagea/#findComment-3143853
haha and what should he do when he finds it? because its pretty definite he will.. :stupid:
Haven't seen a stagea without the TINY spot of rust behind the passenger mirror. Not a big deal at all - just something to be aware of. So saying I still haven't done anything about mine, after 1 year of owning it...
it shouldn't put you off buying one. Stageas are VERY reliable as you can tell by the lack of requests for help fixing problems on this forum. Most "help me" threads are self-inflicted in some way, and by that I mean that very few problems would relate to a stock stagea :laugh:
Edited by pixel8r
https://www.sau.com.au/forums/topic/170136-buying-a-stagea/#findComment-3143944
I got mine removed and resprayed when the bodykit was done. I belioeve that would be the best way to do it. And sometimes that patch of rust can be bigger than you think, pull the mirror off and have a look first. Not in all cases but in some it can spread.
https://www.sau.com.au/forums/topic/170136-buying-a-stagea/#findComment-3145048
Defiantly get a compression and leak down test if you can, it'll show you how the actual motor is faring after 8-10yrs of use.
Basically same things as a skyline, if you can looks for shaft play in the turbo as well.
https://www.sau.com.au/forums/topic/170136-buying-a-stagea/#findComment-3145236
You can buy bottles of rust inhibator from hardware stores.
If you are after a quick fix for the rust problem, you could just brush this on under the mirror and inside the door. Then when it's dry, put a layer of paint over it.
Should stop the growth of the rust spot for a few years
https://www.sau.com.au/forums/topic/170136-buying-a-stagea/#findComment-3145900
cheers, thanks for the info!
its been on my "todo" list since I got the car (um...about 14 months ago) - really need to get onto it...
https://www.sau.com.au/forums/topic/170136-buying-a-stagea/#findComment-3146261
  • 2 years later...
I let mine go and the rust spot turned into bubbling paint about an inch under the mirrors. After purchasing, rust proofing and installing two doors my advice is don't wait. Do it now.
https://www.sau.com.au/forums/topic/170136-buying-a-stagea/#findComment-5168995
check under the boot seal too,stageas love to rust there also a couple of guys have had trouble with rust under the roof racks. i hit mine pretty hard with a four inch grinder then rust converter until its all changed colour ,then paint it. Also the electric mirrors can be problematic once they get older but its just a case of pulling them apart and cleaning them up a bit.
https://www.sau.com.au/forums/topic/170136-buying-a-stagea/#findComment-5169118
You can't fix the rust under the mirrors problem from the outside. There is a good tutorial on pulling off the door cards and pulling out the bit of foam that soaks up water and either replacing it with something water resistant or drying it out and waterproofing it.
https://www.sau.com.au/forums/topic/170136-buying-a-stagea/#findComment-5170518
    • All of those are near new/brand new/done under 10,000km! This means something! It also doesn't necessarily mean anything.... The idea is of course to fit wider tyres and rims, and to go with engine head updates, I'm sure it will be faster the subsequent time out. But TBH the difference will largely be in driver mod between one day and the next I'm sure. To say I am unseasoned after many years away from even driving remotely fast is an understatement. Giving it half throttle and "Whoa, that's a bit excessive.." and realizing I'm doing 80kmh in a 100 zone is evidence enough lol. I have noticed that there is heat haze/steam/air/something absolutely steaming out of the car after parking it. I didn't drive it in the 40C day for testing yesterday, but on Christmas day it was ~32 and you could literally see the air coming out from the bay after parking the car. Whether that's enough though..
    • I'll take clutch for 50 Eddie.
    • Standard GTRs are boring and there plenty of them, do what ever you want to it and just remember nothing about them is cheap anymore and if you’re picky about how you want things done it gets even worse.    if it’s an n1 or something very limited then maybe care more about it’s heritage
    • Alright guys, I've got good odds the motor survives due to a majority of spare parts. Who's taking bets on clutch, who's on transmission, and who's go diff? Happy to also take bets on if it still overheats in traffic or not 😛     Car looks amazing by the way. I've never been a fan of R34 rears, so really, I don't think any body kit etc solves that for myself, but the front end looks amazing!
    • As an ex-skyline owner Going off how these things are now "modern classics", I would keep the twins and just "refresh" bits that are required for reliable power and have a car you can take out for a cruise whenever you get the itch As a idiot who cannot leave things alone Going deep into the "rabbit hole" is a easy thing to do, as previously mentioned, once you start it becomes a slippery slope, wirh lots of supporting mods, and possibly rebuilds, and unless you have a bottomless pit of funds, the car can spend most of its life sitting in the garage,  broken, waiting for parts, or building more funds For a classic like a R32 GTR Basically, a reliable OEM+ refresh, that isn't a broken garage queen, is alot better than a car that you build, then break, then fix, then break again And it isn't just the engine you need to worry about, these beasties are getting on in age, and all parts are getting, and have got, expensive, the days of picking up cheap replacement engines and other driveline parts are well and truly over The funds not spent on going a single with quality parts, and with all the other other bits required to make it happen, could be spent on refreshing alot of other parts A wise man once said "If you cannot afford 2 GTR's, you cannot afford 1", I also believe he said this about 20 years ago when you could pick up a clean R32 GTR up for around $20k My advice for a R32 GTR (the one and only true Godzilla in my mind) is to think holistically about the whole car, the body, the power train, the suspension, the brakes, and the driveline SAU is a wealth of knowledge with decades of Skyline experience,  from stock, to OEM+, to modified to varying degrees, to full on or weekend or dedicated racecars, as well as full on money pits that rarely leave their garage Treat the old girl nice and give her what she deserves, you are a lucky man to own such a classic car
