Hey guys.
I am looking to buy a new set of wheels for my GTR33.
I HAD decided to go with a pair of 18X10 +18 running 275 rubber.
It was my understanding that was the widest tire and rim combination possible to run on the GTR33 without modification.
However after speaking to someone else, they said on a GTR32 they are running 18X11 wheels with 305 rubber on them and had to only modify a few bits. :eek:
So that got me to thinking. Initially I didint want to have to modify anything, but hell if I can run a wheel and tire that wide and not have to cut the wheel well or anything, I would happily modify a bit!
So what is the widest possible wheel and tire combination and at what offest that you can run on a GTR33 with minimal modification to the car?
I do mean minmal, meaning I dont want to have to go take my car to a body shop or anything like that. But I have no problem trimming bits here and there and things of the sort.
Also this is going to be on the street, so I need to be able to turn the wheel and make U-Turns and such. However at my power level, I want the most possible rubber on the ground!
Thanks for the help!
btw, I looked at the sticky at the top of this section, however as there were VERY few GTR33s and even less running crazy wide tires, the help it provided was minimal.
-Sayajin
Hey guys.
-Sayajin
18x10.5 with 275x35 or 285x35 will be fine depending on offset but the fronts will rub the inner guards on full lock , not a big problem.
Wow! Are you sure that 285s will fit? If so thats what im going to run!
Of course I mean fit and just rub the inner guard a bit ONLY on full lock.
-Sayajin
-Sayajin
I've had 275x35x18 on 10" rims with 17offset on stock V-spec suspenssion , rears fine, fronts hit on full lock the inner plastic liner. You only travel very slow on full lock so it should be fine .
Don't forget that not all tyres of the same size are the same with, they can vary, you can get say 275's are are only 271mm and others that will be 279mm. If I was you I would go 18x10 with 275x35x18 and 13-20 offset. 13 will be flush with the guards, depending on tyres maybe even stick out a mm or 2 , 20 will be just inside .
Something I learnt recently is that R34 GTR have a bit wider guards at the rear. They can take a bit more offset and wider rim. i.e LMGT4 18x10.5 +15 are ment for R34 GTR not R33... but they do fit an R33 fine with 265's on...
As wrxhoon said, some tyres are wider than others at the same size.... The biggest problem you'll have if you go wide, is you will need to roll your rear guards, not a huge issue, but that's up to you if you want that done or not... If you do you can fit a bit wider rim/tyre... I guss this also depends on how high your car is, if its high then you won't rub at all even if the tyre sticks out :P
Somewhere around 18x10 +20 and 18x10.5 +15..... but the tricky part is, the 10" +20 wheel would be able to fit a wider tyre on it without hitting the rear guards, but you don't want to go to wide since the tyre becomes baggy and that will affect handling...
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 馃槄
    • with the car running (runs fine when temp is cold), I unplugged the MAF and the car stalled.  I have already cleaned it a week ago.  I unplugged the O2 sensor from the left side of the vehicle, and the car was still running.  I let it idle for about 5-7 minutes and shut it off, to see if it would restart, and it did not.  It cranks but doesn't start after engine temp gets up to normal range.   I still need to look at the coolant temp sensor, is this one at the top or bottom of the radiator? Or is it one of the sensor threaded into the T-stat housing?
