hey guys im having afew problems with my car lately, but this is the major one, lately my car has been playing up, car drives fine ( as normal ), so when im on second gear, as i boost it my car just putters ( from the exaust ) and havent even gone past the readline? its the sound like if your cross the redline it putters? but mine comes real early when boosting?
cheers
https://www.sau.com.au/forums/topic/170179-problem-when-boosting/
cheers
If its a popping noise, and assuming its around 4500 - 5000k, your engine is missfiring.
What u need to do is replace your sparks plugs, but get them gapped down from 1.1mm standard, to 0.8mm (this just makes the spark stronger as is doesn't have to travel as far). Also, if you still have the problem, you will need to look at replacing your coil packs. Splitfire is the way to go, check out Slide Performance.
mines doing the same thing - but i already have splitfires and just put new plugs in.......im getting new plugs ordered and going from there, im hoping its not my crank angle sensor (not exactly sure on symptons when that decides to play up)
ive gota go to NGK in adelaide to specially order my spark plugs.......noone here stocks them (sucks having to buy proper race plugs) gonna be an expensive exercise, but if it fixes the problem....360rwkw of fury will be back
what mods you got?
quite a few LOL...........apexi RX6 turbo kit with 50mm ext gate, RB27DET...bottom end consists of R34GTR N1(nismo) crank, conrods and over sized pistons (had a look at this kit from Nismo and its crazy pricing) greddy plenum, 800cc injectors, splitfire coilpacks, dead spark plugs i hope, HKS step 2 cam gears, HKS and Tomei adj cam pulleys, its got the works........LOL
This is just a rough list, theres more internal work and other mods
Edited by Nathan_G1
nice, sound slike a car i wouldnt mess with (for now hehe ) yeah ive ordered my set of splitfire,cam gears, and 550cc injectors, but wont install it till i get a bigger turbo ( still deciding on how much power i want), right after i solve this problem first lol
Edited by komokefe
yeh my problems only recently come into effect, im pretty sure everything is good.........i mean ive driven it before and it ran perfect, then started to miss (which was infact vacc line cut from wastegate to plenum), so i though it was plugs (old plugs were gone anyway), i replaced the plugs and nothings gone right since, so all im doing is getting a new battery and the specific spark plugs i need and i should hopefully be away......i have a lot of drift practice to get too.
if i could recommend you a turbo kit and you werent shy on spending some cash......find yourself an apexi RX6 - for an RB25 these turbo's are amazing dude, minimal lag and so much power to play with
yeah might go for a RX6, not to fussed which brand!! ive had alot of problems with my car for the last recent years! its a head ache ill tell you, even my missus broke up with me coz she thought i was nuts over my recent problems with the car lol but she came back hehe,
anyways found my problem, i found a little hole in my I/C piping and i think theres another which is showing a sign of being a hole lol, can these be welded or just relpace it? ( prize wise )?
but ill still get new spark plugs thou
cheers
exhaust leak will decrease power i think........should definately fix that problem, hole in the I/C piping, shit.....nice find mate, check over it all for any more.
new plugs fixed my car runs crazy again, cost me $75 each spark plug.........retail they were $110, THANKS FOR HELP NGK.
yeah love ngk plugs aye, getting some tommorw hopefully that solves the hisatation wheen boosting, coz after getting the holes welded in it didnt solve the problem, so might check to see if its the plugs....... and plus had the mechanics check my exaust and there were no sign of leaks, BUT he said my car could be running rich coz my wastegate pipe have been leaving black mark on my exaust? lol
    • Oh wow, it's easy to forget how cheap these can be. Probably the cheapest way to travel. Though people in cars here tend to be morons and I would not feel very safe. Were scooters ever big in Australia? It used to be the thing growing up in Europe ~20 years ago. 50/70/125ccm Peugeot or Yamaha and some others. Utterly obnoxious Polini race exhausts. Kick stands that slant as much as possible. So loud. So much noise for really not moving very fast at all. But it felt cool at the time. Not sure where I'm going with this, but there is an aftermarket for mopeds! Though I'd have pictured you more for a Goldwing kind of guy after growing out of the Harley.
    • You need to know I am sorry for this.
    • As the MX5 isn't apparently "manly" enough, and I need something for runs to the local shops, and also take to my part time job at the salon, basically I can keep the MX5 away from car parks and stuff......like "flying lockers", I was wondering what I could buy to fix this issue LOL, I pick up a new Yamaha 125 Delight this arvo from Trooper Lu, basically a R1 that you can fit a slab of beer on between your feet, also, it was $29400 cheaper than a R1, so actually it's 2 x better than a R1
    • Nah. H2S. H2S is "rotten egg gas", which is what is associated with no cat. SO2 is equally nasty, and if you've ever smelt it you'll know all about it. More of a choking, acid in the back of the throat sort of thing. But you can only smell it in a narrow range up to about 1ppm. Above that, it irritates your mucous membranes, but you don't smell it.
    • Kicked the 34 in the guts, she won’t be seeing the road till I get the 31 mobile again.  wont be long and she’s a bit of a garage princess anyway haha
