Hey guys blew standard turbo on my r33 series 1. Looking to replace with something bigger or highflowed that will still bolt up to standard flanges and stuff without modifiacation. Let me know what you got even if its just a standard one. Cheers
Jamie
https://www.sau.com.au/forums/topic/170190-r33-turbo/
we have a hi flowed rb25 turbo $1250
Cheers for the offer, will get back to you.
I'l be saving for the next few weeks, to get a decent amount together....So I cant make any decisions yet, but keep the offers coming....
https://www.sau.com.au/forums/topic/170190-r33-turbo/#findComment-3145209
  • 4 weeks later...
Still after one guys
Let me know what ya got!
Try one of these they at otomoto.com, same turbos as used in ZOOM and HPI Magazine and in the GENTT KITS.
DAMN thats an awsome price for a new turbo. Im in the process of gettng one for my ECR33, just gotta get an RB20DET manual ECU+nistune daughter board=realtime programable management. So if you know ayone with an ecu?? Sorry bit off topic there! cheers,
Hope this helps
KKR480
Big power potential at a baragin price
Internal wastegate with 8psi actuator
Suitable for single-turbo applications on 2.5-4.0 litre engines, or in twin turbo kits on 5.0 to 7.0 litre engines
Comes with 71mm V-band section and V-band for dump pipe, T3 exhaust gasket, oil inlet banjo bolt and oil return gasket.
RRP $899
Specifications for KKR480core:
Compressor inlet pipe 69mm, compressor outlet pipe 50mm
48 trim compressor; inducer 53mm, exducer 76.5mm
Turbine wheel outlet 56mm, outer diameter 73mm
___________________________________________________________________
https://www.sau.com.au/forums/topic/170190-r33-turbo/#findComment-3189745
Hope this helps
Cheers man I might look into them. Why the need for a rb20 ecu? May know of One il let ya know
https://www.sau.com.au/forums/topic/170190-r33-turbo/#findComment-3191505
Bump, still need one guys. No longer want a standard turbo, unless rebuilt recently. Looking for a highflowed turbo of some sort that requires minimal modifying. Thanks guys. Send me a txt on 0415773334
https://www.sau.com.au/forums/topic/170190-r33-turbo/#findComment-3208515
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
