Hey guys blew standard turbo on my r33 series 1. Looking to replace with something bigger or highflowed that will still bolt up to standard flanges and stuff without modifiacation. Let me know what you got even if its just a standard one. Cheers
Jamie
https://www.sau.com.au/forums/topic/170190-r33-turbo/
we have a hi flowed rb25 turbo $1250
Cheers for the offer, will get back to you.
I'l be saving for the next few weeks, to get a decent amount together....So I cant make any decisions yet, but keep the offers coming....
https://www.sau.com.au/forums/topic/170190-r33-turbo/#findComment-3145209
  • 4 weeks later...
Still after one guys
Let me know what ya got!
Try one of these they at otomoto.com, same turbos as used in ZOOM and HPI Magazine and in the GENTT KITS.
DAMN thats an awsome price for a new turbo. Im in the process of gettng one for my ECR33, just gotta get an RB20DET manual ECU+nistune daughter board=realtime programable management. So if you know ayone with an ecu?? Sorry bit off topic there! cheers,
Hope this helps
KKR480
Big power potential at a baragin price
Internal wastegate with 8psi actuator
Suitable for single-turbo applications on 2.5-4.0 litre engines, or in twin turbo kits on 5.0 to 7.0 litre engines
Comes with 71mm V-band section and V-band for dump pipe, T3 exhaust gasket, oil inlet banjo bolt and oil return gasket.
RRP $899
Specifications for KKR480core:
Compressor inlet pipe 69mm, compressor outlet pipe 50mm
48 trim compressor; inducer 53mm, exducer 76.5mm
Turbine wheel outlet 56mm, outer diameter 73mm
___________________________________________________________________
https://www.sau.com.au/forums/topic/170190-r33-turbo/#findComment-3189745
Hope this helps
Cheers man I might look into them. Why the need for a rb20 ecu? May know of One il let ya know
https://www.sau.com.au/forums/topic/170190-r33-turbo/#findComment-3191505
Bump, still need one guys. No longer want a standard turbo, unless rebuilt recently. Looking for a highflowed turbo of some sort that requires minimal modifying. Thanks guys. Send me a txt on 0415773334
https://www.sau.com.au/forums/topic/170190-r33-turbo/#findComment-3208515
