hey guys,
been on the forum for quite some time now and its time for me to move, ive learnt a shit load of stuff here on the forum and greatly appreciate everyones help!. well anyway ill be giving the GTR to my dad (which im very happy about because i dont want to lose it hahaha) and ill be getting a series 8 rx7 :ermm: ill still be hanging around on the forum every now and then though!
anyone know where to go to get a clean example in sydney?. or some trusted importers?
thanks,
https://www.sau.com.au/forums/topic/170225-soon-to-be-new-car/
hey guys,
thanks,
j-spec had a clean one on their website.
those rx7s still look sexy as....good luck with it man....
http://www.japstyle.com.au
They're based in Lansvale. Talk to Ken, say Wil from the forums with the white r33 told you about them. If they don't have anything in stock that you like, then they can keep an eye on the import auctions and import one for you. Just let them know what you want. He's pretty competitive price wise.
It's also best to actually go and check the place out. They're open Sunday too. Just use the website to grab the contact details.
Just remember though, whenever you're buying, get a mechanic to check EVERYTHING if you're going to buy something that they've already got in stock.
hey,
My friend Bought a rx7 series 8 from Fuji Motosports In lansvale... Hes been very happy with it so far and i took it for a drive myself and it was a very smooth drive.... he was very impressed with there service and Price is very very reasonable.. Hes spoke to Sum1 by the name of Trent if dats any help...
Good luck....
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
