  • Replies 99
Hi all , I've had an E mail back from Geoff Raicer to say that he read these TS type threads here . He said the only way to show the difference is to experience both because the difference is really noticable .
In about 6-8 weeks he is going to do some dyno testing in the following configs .
The engine will be a "stock" RB25DET except for the GRedy (sp ?) inlet manifold and a GT3071R turbo so .
1) Std exhaust manifold with a single scroll GT3071R , not sure which A/R housing , tune and dyno .
2) Change to Full Race manifold with same turbo , retune and dyno .
3) Change turbine housing to twin scroll , retune and dyno .
The results should be very interesting though how well the graphs relate to the real world experience is hard to say .
I'm going to ask him if he can log exhaust manifold pressure (turbine inlet pressure) and compare or overlay the numbers to the inlet manifold ones . I don't know if they'll get the chance to try a twin scroll GT3076R and GT3582R but it would certainly answer the question of can bigish (not hugeish) turbos be reasonably responsive without being restrictive on the exhaust side (ie resorting to small A/R's) .
I think also more TS turbine housings are going to be made available but no details yet .
Cheers A .
Warpspeed, i would be very interested in knowing some more about the VNT turbo's that you have played with. I spoke to garrett australia about these a year ago, and they told me that they had not yet reached the development level for high performnce petrol engines, as they could not get the VNT to be reliable with the ex temps.
I have heard that too, but I ran one for three years without any problems with the movable vanes. Porsche now use these turbos on the current 911, so reliability cannot be too bad.
Why is there a problem with also runnung a wastegate if necessary,
Fitting a wastegate is no problem, but what sort of control strategy would you use to control both vane position and wastegate. Think about all this very carefully, and figure out a simple way that does not require full electronic control by the engine management system. There is no simple way, that is the problem.
Just use a tuned size exhaust housing, and then use the vnt to spool it up nice and early. Have you considered the possibility that the overall size of the ex area was too small and thats why the top end sucked?
Yes obviously. You could fit an enormous turbine and housing, but then even with the movable vanes, a GT ball bearing turbo would leave it for dead response wise.
I havent looked into these 100% yet, due to the lack of range of availability, but i can say for sure the vehicles i have driven with VNT turbo's(BMW X5 and Merc 4wd diesel thing)i have been incredably impressed with given their small capacity diesel motor.
Yes, they are good arent they ! But they are diesels not petrol engines, the air (andexhaust flow) is not throttled as it is with a petrol engine. Why don't BMW use it on their turbo petrol engines if it works so well ? Their current turbo petrol engines all use wastegates.
I believe these have totally revolutionized diesels along with single rail direct injection. I believe the ideal turbo for a petrol engined car, would have VNT, possibly a wastegate if necessary
It is nice to speculate. Why do you think Garrett have never fitted variable vane turbines on their GT ball bearing turbos ? If it really worked, companies like HKS would be selling premium performance VNT turbos in all sizes to the hot rodders.
If it was all that good why have the drag racers and rally cars not bothered to use VNT technology ????
The answer is, it has been tried by almost everyone, and it is a real BUMMER. It creates far more problems than it solves on a petrol engine, but works wonderfully well on an unthrottled diesel.
But getting back on topic. I have even tried using a split pulse turbine housing with a second wastegate to block one side of the turbine. Use half the a/r to spool up, then open the wastegate to double the effective a/r to reduce turbine back pressure while holding full boost. A second wastegate then works in the normal way.
I have actually tried this too, and it works. But the improvement is barely noticeable, and it is just not worth doing.
Sorry, greddy inlet manifold.
I already have an hks low mount exhaust manifold.
I think it was the apexi ex manifolds that have the multi flange on the rear 2 ports.
56T 3071 in a .78 twinscroll housing should be good for very high 200's with bullshit good response. I have a battle with a 2835proS/rb25 equiped cef tomorrow evening. We have the same cams, stock bottom ends. It should be interesting to see if the 56T/71mm compressor can knock over my old 52T T04s in the power stakes ;) (assuming he hasn't cheated)
56T 3071 in a .78 twinscroll housing should be good for very high 200's with bullshit good response. I have a battle with a 2835proS/rb25 equiped cef tomorrow evening. We have the same cams, stock bottom ends. It should be interesting to see if the 56T/71mm compressor can knock over my old 52T T04s in the power stakes :P
Well I'd guess the pro S will make it up to around 265-270rwkW tops.
Yours will be good for another 20 (duh!! knowing it has already cracked 288+) at max. Full load figures will be in your favour, but the transient response difference might be different.
If all the theory works out, and Full-Race Geoff can give us some idea with back to back testing, I'd wonder if the split pulse system 3071 can bridge the (perceived) gap between the mid-range/top end surge of the 3076 and HKS offering. In some respects I think either a 48T or 52T T04S based GT30 unit offers a damn good compromise already.
Perhaps that split pulse system with reduced turbine inlet pressure can show it the way for response and outright power? Either way, bring on some results Dave, and Geoff.
Seeing as there is a bit of interest around, with a little bit more searching obviously there’s a bit of discussion going on outside of SAU about split pulse. It’s good to see guys trying to get their heads around the concept and how it applies to cars other than Nissans. I reckon it’s a good thing that BMW mirror Nissan’s approach with I6 configuration, so those guys really use the same/similar techniques when chasing good forced induction performance. Check this out for discussion and pics:
http://forums.bimmerforums.com/forum/showt...ght=split+pulse
Given that MHI do produce split pulse housings, I figure that the Subaru focused discussion on MHI TD05 / TD06 is also worthwhile, given that there are other products than the Garrett units we seem to gravitate towards. Just helps to make a bit of sense when the MHI-based Trust units are commented upon.
http://forums.nasioc.com/forums/archive/in.../t-1081261.html
By battle do we mean dyno or ah drag race . Still lots of variables .
Probably a moot point but given a choise Id prefer a 52T GT3071R , mainly because mid trim compressors generally give slightly better efficiencies and if I could get away with using something slightly less bulky than a T04E compressor cover thats a bonus . I figure that Garrett have used T04B and T04E comp covers on those 71mm GT35 compressors and if the trim was down a tad it would not be the end of the world . It'd basically be a GT2871R 52T with a GT30 turbine instead of the GT28 . Who knows - maybe an RB25 housing to make it say NISSAN and fit std plumbing .
As for Geoff , its about three days work for his business so many thanks to FullRace Motorsport .
Cheers A .
The dyno comparison is handy, and quantifies numbers. Gives something to predict comparative performance.
The drag race tells a fair bit about full load performance but little about daily driven capability.
For me, the tell-all is in something like a hill climb event and/or a sprint event. Something where the max figures on a dyno sheet aren't the most important, but where response and torque delivery from low to full load become significant. After all, that is what this whole split pulse thread is about. :P
For a GT3071, there'd be nothing wrong with a TO4B comp housing. More compact but not really lacking in flow capacity for the application. Less physical size might give fewer clearance problems and a tad easier to plumb up.
Edited by Dale FZ1
Yep they're not as agricultural (the truck type) as people often think . I'm sure people here would have seen the Nissan/Garrett style T04B comp cover , I think its standard on the GT-RS and Garretts marketed GT2871R 52T . Basically 3 bolt outlet and 2 bolt inlet something like I think SR20's have std though there are S13 and S14 variations . Internally its the same as the garden variety T04B .60 A/R housing and there's two variations of that as well ...
Cheers A .
Heaps of different specs being bandied about in this thread.
The HKS GT2835 range uses a couple of different trim specs in the 56.5mm turbine rotor with the 71mm GT35 compressor:
http://translate.google.com/translate?hl=e...hl%3Den%26lr%3D
http://www.j-w-racing.co.uk/acatalog/GT_Ba...bochargers.html
From memory I think BHDave is running a TA series unit which has little in common with the GT series gear. Still like old Grandad's axe with an edge on it though - it'll take your foot off as good as a sharp new one.
The GT30 series units run a 60mm rotor, while those TD06, HY35, and GT35 units are all around 65mm (give or take).
The couple of comp housing options mentioned by Adrian are just that - options. My understanding is their physical size and shape does impact on mass flow capacity and boost response to a degree, but not to the extent of the turbine housing.
I'd taken the units to be tested by Full Race Geoff will be the 60mm based GT3071, using a conventional housing, and the split pulse housing.
Yes anyone with their thinking cap on wouldn't bother with the cropped version and unless it was the Pro S GT2835 it wouldn't bolt up anyway (wrong flange) .
The GT3071R's I've seen Geoff use on SR20's also used his split pulse manifolds and they are T3 flanged . Anyone who looked at the thread I mentioned a while back should also have noticed that their GT3071R's had the T04E compressor housing with the smaller inlet snout or boss . Off the top of my head this boss measures 2.75" instead of 4" so a bit easier to plumb .
Also the cropped turbine at 56.6mm is a bit small to be going into a GT32 turbine housing that had a 64 odd mm turbine originally .
Cheers A .
Porsche are the only manufacturer to use them, and they also run wastegates, and the whole thing is controlled by the engine management unit.
Thats what I was going to suggest, why haven't they (garret etc) developed any that use a wastegate also?
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
