need? are you sure now? :laughing-smiley-014:
probably should pull them to find out, but yeah, them seem well fracked =)
thought they may have just been performance pads, but even when they are hot they squeal like little piggies!!! (mebe not so little piggies..)
https://www.sau.com.au/forums/topic/170240-need-new-brakes/#findComment-3144891
Squeel doesn't mean you need new pads..
Grinding does. lol :P
Your probably missing the anti-squeel shims on the back of the pad. My Ferodo's squeel like all buggery just before coming to a stop as I don't run the anti-squeel's. I couldn't fit them on as the pad had a heap of rubber type crap on the back of it.
Probably could have got them in there but didn't have much time to play around with it.
In the past I've used PBR antisqueel grease with the antisqueel shims and the brakes have been silent. Even when I ran around with Ultimates that are renowned for squeel.
Ultimates = crap. Didn't last long, lots of dust and ate my disks.
https://www.sau.com.au/forums/topic/170240-need-new-brakes/#findComment-3145238
What usage would u get out of em? (where would u be driving them the most?)
I use RB74's on the front as i feel that anything more expensive for the street (where most of my driving is done) is pointless..They hardly dust at all
I had my gtr calipers rebuilt with new seals, then had the rb74's put in with new anti-squeal shims + used the copper grease supplied (shims + copper grease come in a kit from nissan for sfa) Installed em all, then went for a bed in (as i had the rotors machined fresh as well.
Basically went fer a few 80-40 rolling stops and had em smoking. U could smell it hard...
By the time i got to my driveway i could lock the front brakes easy.
They have never squealed ever. Iirc they are $150 for the front set from racebrakes, who can send em to your door COD as well :wub:
EBC arnt the best either...Ds2500 would be the next best one up from the rb74's...but then your looking at ~$240 a set :S
Edited by Bl4cK32
https://www.sau.com.au/forums/topic/170240-need-new-brakes/#findComment-3145255
got a reply from Racing Brakes today...
"In that pad we do not do RB74, I would be putting endless vn9500 in your car"
Wouldn't advise getting any of the VN range, they're not performance pads. If you do go Endless go SS-S or SS-M.
https://www.sau.com.au/forums/topic/170240-need-new-brakes/#findComment-3156084
    • I have engineer in my job title One of or motto's though is "we make and we break"
    • This is actually 2 whole different trains of thought that need to be addressed separately. No, as Matt says above, "Engineer" is not a directly protected title. A lot of guys who just do mechanical design via CAD, with or without even some sort of associate diploma in engineering, often have the job title of "Design Engineer". A train driver can probably still describe themselves as an engineer. But, to usefully get employment with anyone as a proper engineer, you're going to have to have at least the necessary and relevant degree qualification. You're not going to get a job as an electrical engineer if you have a chem eng degree, unless you can demonstrate x number of years of working in that capacity, sufficient knowledge, etc. Having the degree is at least in indication that you've seen the relevant text books, even if you haven't read them (like pretty much the last 10 years of graduates!). To be a self employed engineer.....you could get away with quite a lot pretending that you're suitably qualified, without actually being a proper engineer. But, you will find yourself unable to work for a large section of the client space because a lot demand CVs and capability statements when considering contracting for any engineering work these days. Insurances too. If you're not a proper engineer, it will be much harder to obtain proper PI insurance. Insurance companies have gotten hip to that. The "Professional Engineer" thing is a thing in Australia. If you have the right qualifications and experience you can apply to the relevant engineering top level body (mostly Engineers Australia, the less said about whom, the better), to be assessed and approved as a Chartered Professional Engineer, CPE. There are high bars to get over and a requirement for CPD to maintain it. The RPEQ thing is similar-ish, in that you have to demonstrate and maintain, but the bars are a little lower. It is required to be RPEQ in order to sign off as an engineer on any engineering design in Queensland. The other states haven't fully followed suit yet. There's "engineering" and there's "engineering". Being an engineer that signs off on timber (or even steel) frames for housing projects, council creek crossing bridges, etc, is a flavour of civil engineering that barely warrants the name, description and degree. That would be soul crushing work anyway. Being an automotive engineer working in the space where you have to sign off on modifications to cars and trucks would also be similarly soul crushing. At least partly because of the level of clientelle, their expecations, depths of bank balance, etc. And that brings us to your second question. No, we do not have professional engineers "do vehicle inspections". Well, not the regular roadworthies, etc etc. That's done by mechanics. There might be some vehicle standards engineers at the various state govco inspection stations where cars go to get defects cleared and so on, but that's because they (the cars) are there specifically for defect inspection and clearance and so the stakes are a little higher than on an annual lights and brakes working check. But, if you modify a vehicle in Australia, you have to get it engineered. A suitably qualified (and effectively licensed, which I will get back to) automotive engineer will have to go over the application, advise on what would be required to make the mods legal, supervise some parts of the work, inspect and test the results, and sign off. The "licensed" aspect comes from there being a list of approved engineers to do these things in each state. They have to jump through hoops set up by the govco vehicle standards divisions that mean only the suitably qualified can offer to and approve such mods.
    • It's got a problem Prank... It looks like both washer spray caps have fallen off this car... 😛
    • Meh, it's only got to last another 10 years or so until you'll be forbidden to drive it. Keep it dry and forget about it.
    • The title of Engineer is not protected. However different states have different rules about what an Engineer requires to operate. Engineering for a motor vehicle modification is very different to engineering for a bridge, electronics, etc, including what that engineer needs as certifications.   In Canberra, "Engineer" is the loosest category with basically nothing stopping you calling yourself and engineer and designing a bridge or building. From what I've reviewed, QLD has the strictest requirements through RPEIQ.
