I need to know if a GTR rear hub will bolt onto a GTST, i know the spline is different but is anything else.
I am getting a diff that will go in my car but it has GTRinsides including the driveshaft pattern, so i need to fit the GTR driveshaft and hubs to my gtst suspension will this work.
Any help appreciated
https://www.sau.com.au/forums/topic/17025-help-gtr-and-gtst-rear-hub-question/
I asked the same question concerning GTR/300ZX rear hubs. I wanted to know if the GTST is aluminium like the GTR/300ZX.
I for one would be interested to hear the answer if you come across it.
Im not sure if the GTR and 300ZX hub are the same, i know the 300ZX hub can be used on the S13 Silvia when doing the 5-stud conversion, havent read that the GTRs can also be used.
The gtst rear hub is steel, i wanted to know if the gtr and 300zx are the same.
You use a n/a 300zx rear hub on a s13 as they bolt on and have the same spline. In my cas i know the gtr spline is different and i need the gtr driveshafts and hubs. I just dont know if the hubs will bolt on the the gts or not.
Sorry, but like i said, i dont really know if they are the same. :rolleyes:
But would be interested if you could post how you fair with chasing down the info.
I was hoping to replace the steel GTSt (R32) hubs with aluminium hubs off a 300ZX(TT or NA) GTR etc, etc but couldnt find any answers.
Good luck!
  • 6 months later...
dont know how u went with ur inquires but i hav just gotten the whole arse end of an r32 its has the alloy hubs on it with gtr suspension as wellona its on a gtst wreak body cheers Peter
  • 20 years later...
Im wanting to know as well but what i have come across so far from mixing and matching hubs and axles. is...
R32,33,34 (GTR) hubs are 32 spline i also know the R33gtr and R34gtr hubs are interchangeable but im not so sure about R32.
The NA 300ZX is 29 spline hub which fits into just about any silvia or skyline thats not GTR  but the 300ZX(TT) is 32 spline like the (GTR).
Another option to look into is the Stagea RS four (AWD). The Stagea RS four(AWD) also uses the same wheel hubs as the R33/34(GTR) so..  if they do bolt onto the GTST knuckle then you have all these other options to pick from.
i didnt really awnser the question but hope this info helps
im doing a 350Z LSD conversion on my r34 rn. I have everying but i found out the 350z Rear hubs don't bolt onto my rear  knuckles but they are also 32 spline. i was just thinking wether or not the r34 GTR hubs fit before i have to buy them and find out lol.
daymn i just realised im way too late this was from 2003
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
