G'day,
I have a set of R34 GTR rims that I will fit onto my R34 GTT (Coupe) fairly soon. I understand that R34 GTR will fit fine to R34 GTT (hence I got them).
I have very little experience when it comes to tyres sizes and I would like to ask for your kind help.
There are many discussion on whether R34 GTR rims will fit R34 GTT. However, I have not found any regarding tyre size (Yes, I have use the search but nothing really answer my question directly). I am looking for tyre size that can fit my car with minimal modifications on guard or whatsoever or even none (if possible). I also understand that there might be minimal rubbing depending on the size of the tyre I will be using.
So the question is:
What is the best tyre size to use on an R34 GTT with R34 GTR rims?
Any suggestions/comments will be highly appreciated.
P.S. Any suggestions on the tyre brand/model will be great.
Thanks for the reply XKLABA
The GTR rims currently have 245/40 all 4. However one is pretty bald and hence will need replacement soon.
Just want to get a confirmation to make sure that I have used the correct tyre size,
Anyone has R34 GTR rims on your R34 GTT with 245/40??? How is it going??? Any suggestions???
Thanks
Thanks n15m0.
So you reckon 225/235 would be fine?
I need to get a pair of new tyres soon. I was thinking 245/40 at front and 265/35(I found some second hand tyres in this size) at rear.
Anyone can confirm that 245/40/R18 will rub the guards on an R34 GTT coupe?
Cheers
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
