I SERIOUSLY doubt you'll find a ball-bearing turbo for under $1500. AFAIK the Highflowed SLIDE turbos are plain-bearing. In fact, I don't know that I've seen ANY ball bearing turbo's around, highflowed, new. or otherwise for under $1500. There's T3/4 hybrids kickin about new for $500 or less, but they're oil-cooled only cores. not too sure on quality or performance either.
hmmmm.. . . . . . .
How does the highflow compare to the std turbo? How noticable is it and how much diff in pwer?
Well mine isn't a slide (I'm sworn to secrecy) but I get the impression it's a similar result in power, lag, efficiency etc. The spool-up below 2,500rpm is possible, but not in the same game as the stockie. Above 3,500rpm tho, it kicks like a frikken Mule ! ! It's definitely not as "ready to go" about town when You're cruisin & give it a prod, but when you've got a few revs onboard to begin with, it's GOLD !
I don't even notice the lag 99% of the time now, just used to it I guess, & automatically adjust/pre-empt.
So its much better than standard (disregarding lag etc)? Both cars I have owned hve been turbo and Ive never upped the boost/changed a turbo before so have never had an idea of how big the increase is.
Lag is not that bad with the standard slide hi-flows, for the small amounts of loss in response there is big time gains in both mid-range and top-end power. Even if you feel it is a bit laggy there are cheap ways of improving response without breaking the bank ie. Retarding ex cam gear, advancing base ignition timing with CAS adjustment, high-flow cats, high flowing mufflers etc.
The power difference is very noticeable, boost hits hard and keeps on pushing rather than plateauing like the standard turbo's do.
Edited by BAMR33
Oh I wouldn't bother with a dead-stock Skyline, I drove a few when I bought mine, and it just ain't no fun !
I'm at about 200rwkw, and I'd say that's just nice for a road car (I've got a fat torque curve tho, 16psi boost midrange, 'til the injectors hit 100% at 5,500rpm) but just barely a starting point for trackwork, IMHO. About 18psi and 250rwkw feels REAL fiesty on the road, I've ridden in one a couple of times, and it'll light up both rears in 2nd, straight-line style. =D
The stockie's restrictive exhaust housing/exducer limits flow to 180rwkw, 190 if you're lucky (or your dyno reads optimistically)
Stock turbo comes on smooth & quick, but ultimately won't set your pants on fire. The real-deal "turbo rush" comes from the laggier, harder-hitting delivery of bigger-flowing turbos.
It's fun :/
1. No frount mount.2.Standard clutch ( when you say my clutch should be replced is this because its going to slip from more power? Or your all just assuming im going to be drifting and doing burnouts?)3.Standard fuel system.4. Piggy back ecu ( IS that what the SAFC does?)
I have a turbo back exhaust (with standard dump pipe),
That's not a 'turbo back' upgrade exhaust.
You'll want to replace the front/dump pipes if yours are standard.
If $$ is an issuea (which it was for me), just get an all in one front/dump 3" from flying performance www.flyn.com.au or something similar.
hmmmm.. . . . . . .
True if you're looking at brand new althought there is/was? a 2nd hand GCG high flow in the for sale in the last few days for $1350 i think and i got my HKS2535 delivered for $1200 from Japan (plus extra expenses on that one though for line etc)
For me, I'd go the 2nd hand GCG over a new Slide but that's just my personal preference.
Yeah Its just the standard dump I have, I have the 3inch Jasma front pipe :/ I will get onto replacing it. Whats better? 2.5Inch split ebay stuff or like a 3 inch single pipe exhaust shop job??
I can never remember which bit is which , front and dump. :/
Do a ring around some zorst places and ask how much to replace that piece then make your own decision.
Yeah will do. Ps dump is right off the turbo front is from dump to cat
  • 2 months later...
Sorry to bring up an old thread guys,
but with this set up - what injectors do you guys use? or what to reccomend?
Ive got the slide hi-flow with other mods like powerFC,EBC, walbro fuel pump
Only thing now that is restricting me is the AFM and injectors
Reccomendations guys?
Cheers,
Chris :)
i have had a slide highflow on my 33 for about 8,000ks now,you can feel more power straight away,but you diffnately need a aftermarket ecu,i have only got the stock computer in at the moment,will put one in soon hopefully,with my car being auto,need to look for a computer that can run the autos well.also will get a high stall,fuel pump etc,but the car and the turbo has good potential to run a low 12sec or even a high 11 second pass,no doubt :P
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
