I SERIOUSLY doubt you'll find a ball-bearing turbo for under $1500. AFAIK the Highflowed SLIDE turbos are plain-bearing. In fact, I don't know that I've seen ANY ball bearing turbo's around, highflowed, new. or otherwise for under $1500. There's T3/4 hybrids kickin about new for $500 or less, but they're oil-cooled only cores. not too sure on quality or performance either.
hmmmm.. . . . . . .
How does the highflow compare to the std turbo? How noticable is it and how much diff in pwer?
Well mine isn't a slide (I'm sworn to secrecy) but I get the impression it's a similar result in power, lag, efficiency etc. The spool-up below 2,500rpm is possible, but not in the same game as the stockie. Above 3,500rpm tho, it kicks like a frikken Mule ! ! It's definitely not as "ready to go" about town when You're cruisin & give it a prod, but when you've got a few revs onboard to begin with, it's GOLD !
I don't even notice the lag 99% of the time now, just used to it I guess, & automatically adjust/pre-empt.
So its much better than standard (disregarding lag etc)? Both cars I have owned hve been turbo and Ive never upped the boost/changed a turbo before so have never had an idea of how big the increase is.
Lag is not that bad with the standard slide hi-flows, for the small amounts of loss in response there is big time gains in both mid-range and top-end power. Even if you feel it is a bit laggy there are cheap ways of improving response without breaking the bank ie. Retarding ex cam gear, advancing base ignition timing with CAS adjustment, high-flow cats, high flowing mufflers etc.
The power difference is very noticeable, boost hits hard and keeps on pushing rather than plateauing like the standard turbo's do.
Edited by BAMR33
Oh I wouldn't bother with a dead-stock Skyline, I drove a few when I bought mine, and it just ain't no fun !
I'm at about 200rwkw, and I'd say that's just nice for a road car (I've got a fat torque curve tho, 16psi boost midrange, 'til the injectors hit 100% at 5,500rpm) but just barely a starting point for trackwork, IMHO. About 18psi and 250rwkw feels REAL fiesty on the road, I've ridden in one a couple of times, and it'll light up both rears in 2nd, straight-line style. =D
The stockie's restrictive exhaust housing/exducer limits flow to 180rwkw, 190 if you're lucky (or your dyno reads optimistically)
Stock turbo comes on smooth & quick, but ultimately won't set your pants on fire. The real-deal "turbo rush" comes from the laggier, harder-hitting delivery of bigger-flowing turbos.
It's fun :/
1. No frount mount.2.Standard clutch ( when you say my clutch should be replced is this because its going to slip from more power? Or your all just assuming im going to be drifting and doing burnouts?)3.Standard fuel system.4. Piggy back ecu ( IS that what the SAFC does?)
I have a turbo back exhaust (with standard dump pipe),
That's not a 'turbo back' upgrade exhaust.
You'll want to replace the front/dump pipes if yours are standard.
If $$ is an issuea (which it was for me), just get an all in one front/dump 3" from flying performance www.flyn.com.au or something similar.
hmmmm.. . . . . . .
True if you're looking at brand new althought there is/was? a 2nd hand GCG high flow in the for sale in the last few days for $1350 i think and i got my HKS2535 delivered for $1200 from Japan (plus extra expenses on that one though for line etc)
For me, I'd go the 2nd hand GCG over a new Slide but that's just my personal preference.
Yeah Its just the standard dump I have, I have the 3inch Jasma front pipe :/ I will get onto replacing it. Whats better? 2.5Inch split ebay stuff or like a 3 inch single pipe exhaust shop job??
I can never remember which bit is which , front and dump. :/
Do a ring around some zorst places and ask how much to replace that piece then make your own decision.
Yeah will do. Ps dump is right off the turbo front is from dump to cat
  • 2 months later...
Sorry to bring up an old thread guys,
but with this set up - what injectors do you guys use? or what to reccomend?
Ive got the slide hi-flow with other mods like powerFC,EBC, walbro fuel pump
Only thing now that is restricting me is the AFM and injectors
Reccomendations guys?
Cheers,
Chris :)
i have had a slide highflow on my 33 for about 8,000ks now,you can feel more power straight away,but you diffnately need a aftermarket ecu,i have only got the stock computer in at the moment,will put one in soon hopefully,with my car being auto,need to look for a computer that can run the autos well.also will get a high stall,fuel pump etc,but the car and the turbo has good potential to run a low 12sec or even a high 11 second pass,no doubt :P
    • Yeah, that's when. I guess you could say I'm as patient as I am foolish(or just a masochist?🤔). I've strongly considered throwing in the towel and calling it all quits many times, and have almost done so. It's a first-world problem for sure, but I've had a pretty rough go of it, as well as other factors; hoping something good comes of all this; it has to. It definitely is half the price of the ATS and performs great, but I'd like to try something different for once. I've sampled the ATS in a friend's 32 and it's solid👍
    • I know mentally you're set on the ATS clutch but honestly I'm a big fan of the Nismo Super Coppermix Twin. It's much cheaper and in some ways I think it's a better design for a street/circuit car.
    • Just checked in first post and you should be able to bring it home November this year, right? I'm amazed you made it through four years of this. As hard as it feels now the rest will go by in a breeze in hindsight, I'm sure.
    • Realized I haven't been back here in a while. Still here, still alive, still waiting for the car.  I went back again the only time last year from Oct-Nov for R's Meeting and drove it around some more, including a few laps on Fuji Speedway(in the wet, sadly). The car still feels good, but have a couple small things to address. I've been getting more parts but have slowed down still, and most of the bigger purchases are now out of the way. I find myself getting impatient more and more when it comes to getting started on this project; it's quite hard for me not being able to really dive in and start making this car my own because it's halfway across the world. At times it doesn't even really feel like I own one of these. Haven't really been motivated or had the desire to document the last trip on here or social media for, well, reasons... but here's some pics...it's also still alive and well as you can see: I've narrowed down to the last large part purchases(anything over $2k) before the engine build to be: 1) Ohlins Road & Tracks 2) ATS Twin Carbon clutch 3) Endless BBK with some custom options and 4) Kansai Service carbon driveshaft I don't think the budget exists for all of these this year, but I'll try for one or two items I think. Though, every time I look at my spreadsheet I sigh, shake my head, and get depressed just that little bit more.  'til later.
    • It's a stunning location!  I've been to NZ twice but haven't made it to the North Island yet.  Definitely on the cards but the South Island is hard to tear yourself away from too... Looking forward to see what you can wring out of it once you can get it to hold together!  Be awesome to get a low 11 or even sneaking into the high 10's pass out of it.  That's a bloody quick car that most people will never experience in their life.  Enjoy!
