WogsRus Posted May 28, 2007 Share Posted May 28, 2007 what turbo is this an R32 or R33. Standard or highflow? Link to comment https://www.sau.com.au/forums/topic/170320-what-turbo-is-this-from/ Share on other sites More sharing options...
DRD-00F Posted May 28, 2007 Share Posted May 28, 2007 thats a stock T3 from a 33... and by the looks of both wheels being steel, the bore size being right at the edge, and the centre metal nut being cut for balancing... i would say its a highflow R32 turbo Link to comment https://www.sau.com.au/forums/topic/170320-what-turbo-is-this-from/#findComment-3145965 Share on other sites More sharing options...
WogsRus Posted May 28, 2007 Author Share Posted May 28, 2007 (edited) that is what i was figuring. Could one use this on an R33 for gains? It is fully recoed and so forht. I am mainly after it because i think the wheel is steel. Edited May 28, 2007 by WogsRus Link to comment https://www.sau.com.au/forums/topic/170320-what-turbo-is-this-from/#findComment-3145970 Share on other sites More sharing options...
DRD-00F Posted May 28, 2007 Share Posted May 28, 2007 yes and no... im pretty sure the exhaust housing on the 33 was larger... so even from a stock 33 turbo, it wouldnt be much of an upgrade... especially if you have to pay for it... then theres the oil lines and what not, i have no idea if it would perfectly fit up... If your paying any sort of money for it, get a high flowed 33 turbo from slide, $890 delivered i think... Link to comment https://www.sau.com.au/forums/topic/170320-what-turbo-is-this-from/#findComment-3145976 Share on other sites More sharing options...
WogsRus Posted May 28, 2007 Author Share Posted May 28, 2007 hows $200 fully recoed sound never run? My turbo is ok but i was wondering what this might do. The guy has no idea on specs and is cheking it out, so i will post once i get it. But i think the Rb20 trubo has same size banjos as the Rb25??? no??? Link to comment https://www.sau.com.au/forums/topic/170320-what-turbo-is-this-from/#findComment-3145983 Share on other sites More sharing options...
Cubes Posted May 28, 2007 Share Posted May 28, 2007 Its neither.. Definitely not an R32, R33, VG30DET, rb26 anything... Its some sort of garrett gt25 or gt28 turbo. Does it have the regular T3 flange? BB turbo's are not servicable. So its not reco'd. It will be either new or used. When so called reconditioning turbo's they use the old housings; throw out the old center and replace it with a new item. So essentially a bran new turbo minus the housings which is not to be concerned about anyway. Link to comment https://www.sau.com.au/forums/topic/170320-what-turbo-is-this-from/#findComment-3146019 Share on other sites More sharing options...
Butters Posted May 28, 2007 Share Posted May 28, 2007 Its neither.. Yep I agree. If you look at the bolt pattern on the exhaust housing that won't bolt up to a 32 / 33 style dump pipe. Are you sure it is T3 and not T2 ?? Link to comment https://www.sau.com.au/forums/topic/170320-what-turbo-is-this-from/#findComment-3146027 Share on other sites More sharing options...
WogsRus Posted May 28, 2007 Author Share Posted May 28, 2007 definatly a T3 turbo to manifold flange, and different for the back but yet to confirm details. Either way it has never ben on a car since being recoed or rebuilt or what ever. I have been told it will fit the R33 but have to wait to confirm details. Link to comment https://www.sau.com.au/forums/topic/170320-what-turbo-is-this-from/#findComment-3146057 Share on other sites More sharing options...
MANWHORE Posted May 28, 2007 Share Posted May 28, 2007 (edited) thats a stock T3 from a 33... and by the looks of both wheels being steel, the bore size being right at the edge, and the centre metal nut being cut for balancing... i would say its a highflow R32 turbo Incorrect. It's NOT NOT NOT an r32, 33 or 34 turbo. this has 5 bolt dump pattern. the gtst turbos have 6 bolt. Looks like it's either a gtr turbo or a t25/t28 from a silvia or something. That is about as far from a stock nissan turbo as you can get. r33 turbo says nissan 45 v on the comp housing. r ugly poo says nissan motors 16v Edited May 28, 2007 by MANWHORE Link to comment https://www.sau.com.au/forums/topic/170320-what-turbo-is-this-from/#findComment-3146061 Share on other sites More sharing options...
WogsRus Posted May 28, 2007 Author Share Posted May 28, 2007 the front cover look like it says AR.44 Link to comment https://www.sau.com.au/forums/topic/170320-what-turbo-is-this-from/#findComment-3146067 Share on other sites More sharing options...
WogsRus Posted May 28, 2007 Author Share Posted May 28, 2007 so untill i get the specs the consensus is that it's a carp upgrade? Link to comment https://www.sau.com.au/forums/topic/170320-what-turbo-is-this-from/#findComment-3146072 Share on other sites More sharing options...
MANWHORE Posted May 28, 2007 Share Posted May 28, 2007 Hey wogs Well, once you get it bolted on etc, it will probably be an upgrade (being a garrett turbo with steel wheels, you shoudl be able to run more boost). But we're not sure if it even is t3. If it's not, it won't bolt up to your mani. You'll definitely need a new dump pipe (or at least have the flange changed on it). You'll most liekly need new oil/water lines (like other garett turbos) i.e. if it even is watercooled, otherwise just oil lines IC piping may or may not bolt up (looks like it should) Link to comment https://www.sau.com.au/forums/topic/170320-what-turbo-is-this-from/#findComment-3146081 Share on other sites More sharing options...
WogsRus Posted May 28, 2007 Author Share Posted May 28, 2007 thanks guys, i'll await the specs, but for $200 if it is ok, it's a steal, eaven to sell it again. LOL. Yeah thanks all, i simply have no idea what it is. I rang the guy an i should know within a couple of days exact specs. Link to comment https://www.sau.com.au/forums/topic/170320-what-turbo-is-this-from/#findComment-3146098 Share on other sites More sharing options...
BHDave Posted May 28, 2007 Share Posted May 28, 2007 It's a t3g. Old plain bearing hks unit, good for about 210-215rwkw. They usually come with a dump pipe that matches up to your front pipe due to the different outlet flange. Link to comment https://www.sau.com.au/forums/topic/170320-what-turbo-is-this-from/#findComment-3146100 Share on other sites More sharing options...
WogsRus Posted May 28, 2007 Author Share Posted May 28, 2007 well i'm making 217 rwKw on a standard turbo. LOL. Link to comment https://www.sau.com.au/forums/topic/170320-what-turbo-is-this-from/#findComment-3146110 Share on other sites More sharing options...
DRD-00F Posted May 28, 2007 Share Posted May 28, 2007 Incorrect. It's NOT NOT NOT an r32, 33 or 34 turbo. this has 5 bolt dump pattern. the gtst turbos have 6 bolt. Looks like it's either a gtr turbo or a t25/t28 from a silvia or something.That is about as far from a stock nissan turbo as you can get. r33 turbo says nissan 45 v on the comp housing. r ugly poo says nissan motors 16v hey man, does it look like i know everything about turbos? do you think its my main area of expertise??? i was basically saying that it wasn't a 33 turbo, and being as how he gave a choice of 2, i took a stab in the dark... and missed knew someone would come and correct me Link to comment https://www.sau.com.au/forums/topic/170320-what-turbo-is-this-from/#findComment-3146113 Share on other sites More sharing options...
WogsRus Posted May 28, 2007 Author Share Posted May 28, 2007 well i know less then all of ya. LOL. only seen my turbo once when i took it off, and never payed enough attention to know different. and the whole T3 T2 thing got me stumped. Thanks guys Link to comment https://www.sau.com.au/forums/topic/170320-what-turbo-is-this-from/#findComment-3146123 Share on other sites More sharing options...
TTT Posted May 28, 2007 Share Posted May 28, 2007 Listen to the guy with the bad hair named Dave. not an upgrade for your car. not a direct bolt on for anything. save your $200 or send to to "happy dude" Link to comment https://www.sau.com.au/forums/topic/170320-what-turbo-is-this-from/#findComment-3146569 Share on other sites More sharing options...
