hey all,
while driving on the freeway in 5th i was half booting it and all of a sudden.. no power, nothing the car just cut for a split second then kept going feeling abit sluggish (could be paranoia) but didnt feel right. stopped at the lights later and then the car stalled. i started it back up and it was all fine. drove it home and it happened again like the engine was compeltely non responsive howevr this time it died. i pulled over and then started it again and it worked fine.
This all happened again today so i dropped it into the mechanics just to be safe and he says its my afm, and it will cost 400+ to recondition. could this problem be anything else like coils or something? and if it is afm would the tutorials i found on soldering etc be relevant?
thanks for the help
https://www.sau.com.au/forums/topic/170346-dodgy-afm-other-problems/
it definately sounds like AFM, but dont pay $400 to have it 'reconditioned'. You can try getting some electical contact cleaner and cleaning it with that, but you should be able to find a 2nd hand afm for < $100.
the poor performance could be due to coilpacks causing a miss, but the stalling and hunting is indicative of an AFM problem.. Plus the fact your mechanics said the same thing certainly points towards it... Only way to see for sure would be a CONSULT hookup.
I don't have this problem but i recently swapped mine out and sold the old one.
It was working fine but had a lot of greasy build up in there.
CLEAN IT YOURSELF GUYS.
If you've never seen one, the actual sensor part of the filter looks so small and delicate I'm suprised these things atcually work! :/
Get a can of contact cleaner and spary to your hearts content. Leaves no residue and heaps of crap will come off.
You're safe to spray the wire sensor too.
Pics here of one removed : http://people.aapt.net.au/~jason1973/Ebay/
To remove the AFM will take a good 5 mins with 4 bolts and 1 hose clamp.
So even if you've never done anything mechanical in your life, this is a good place to start.
$400 for a recon!!! I bet he would do the same spray i suggested, what a rip!
Brand new Z32 is around $350 for goodness sake.
(By the way, i sold mine, working, for $50)
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
