Hi all
I have a thread in the WTB section here: http://www.skylinesaustralia.com/forums/in...=170351&st=
Does anyone know of any genuine AUS R32 GT-Rs for sale - or at least a few things to look for to know if it's a genuine one or not?
Thanks
James
https://www.sau.com.au/forums/topic/170352-aus-delivered-standard-r32-gt-r/
basic things to look for are:
rear number plate surround does not have reverse lights either side
outer rear brake lights are also the indicator and have an orange lense
they have the under car coolers too, but these have sometimes been removed
Marcus will be able to tell you what makes an Aus GTR an Aus GTR. I saw one for sale in NSW not so long ago for around $40K. It was stock.
interesting - evo for sale, and now aus delivered gtr? unless, this is going to go to p1 international :O
edit: wasnt there another aus del r32 gtr on sale here toward the end of last year or something? not sure if it was in vic or not..but was a silver one i think
post the differences butt munch!
this one looks ok:
http://www.carsales.com.au/used-cars/priva...matchallpartial
this is the one for sale on UAS too. A bit less desireable I reckon as it has twice the kms and more mods.
I take it I am butt munch then...
0. came only in Black, Red and Silver
1. side repeaters same as aus 300zx (long) and probably clouded now (deleted on my car now)
2. roof mounted antenna which is rubbish (deleted on my car now)
3. probably has nice 'nissan' mudflaps
4. transfer case cooler near rear diff (mine busted and gone)
5. rear lights different - outer circles are indicators, square between circular lights is reverse, inner circle is brake
6. 260km std speedo - no GTR markings or anything (by memory)
7. additional dimmer switch on RHS of dash cluster for dash lights
8. rear high mounted LED brake light (in top of window)
9. kid seat mounts in parcel shelf
10. obviously a "Nissan Australia" build plate on the LHS (passenger) of engine bay behind ABS unit
11. plastic trim piece that covers the rear number plate area and is the full width deleting the reverse lights there (part no longer available from nissan so don't get rear ended!)
12. nissan badge on bonnet instead of "S" badge
Ask and you will receive!
AusGTRspecs.pdf
There was a RED one for sale a while a go by one of our members too, he was at the Show and Shine that SAU VIC held at South Bank!
I decided to keep it. Even thought i don't drive it much any more. :P
Don't have the time
make sure there is the orig dealer log book too.
Edited by Zardos
    • Middle seat good for a slab of beer or Esky for a road trip. 2x kids, means 1x free seat lol.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
