Hi guys, we have some issues with the GTR. It can't develop boost more than 0.6 to 0.7bar(on twin 34 n1). However, the car drives absolutely fine within 0.6bar, all readings are as should be. We have tried to look fer many possibilities, firstly the most possible being a leak somewhere. All hoses and pipings dont seem to have any leak at all. Both turbos tested flow the same and flow very well when testing the flow out of the turbos directly. We have tried tightening the actuators more than it should be to push 1bar, but it still does not push more than 0.6bar. At first we were told that the boost solenoid of the old hks evc had gone, so a brand new avc-r has been put in, but it DIDN'T solve anything. Only thing we are onto is that the outlet side of the front mount intercooler doesnt seem to be pushing out air as strong as from out of the turbos. Could it be a clogged or leaking intercooler core? How should we go about testing it(pressure test?) n who is a good person to sort this out in brisbane?
The last track day we had quite a lot of blowby and oil did splutter out of the catch can and maybe it clogged up the intercooler? We saw decreasing max boost on the track that day from like 1.3bar dwn to 1.1bar, then down to 0.7bar and ever since it seems to be clogged and cant develop high boost. That said, i dunno if the oil is the cause of the boost problem. However, car drives absolutely normal when we put it back on stock 0.5bar of boost ever since then cuz the problem is still not sorted. I don't recall anything coming into physical contact with my frontmount to cause a crack etc at all. Im running out of answers to this boost problem. Wot other possibilities can there be fer the cause of not being able to hit high boost???
Need some help urgent in brisbane! Recommendations for someone who knows turocharged skylines and track cars very well and is free to get this sorted out will be greatly appreciated!!
Edited by J-Boy
https://www.sau.com.au/forums/topic/170370-unable-to-develop-high-boost/
Yeah im planning to have the intercooler off and checked, wot kindda checks should be done on it? And wot kindda remedies are there for a clogged intercooler core, or is it only thru replacement of the whole core itself?
Well that would be depenadant on whats causing the block if that is infact the issue.. If its a damaged core you would see damage on the outside of the cooler. So i wouldnt expect that to be the case. If it is infact experiencing a large pressure drop across the core you all of a sudden you should be able to get an idea whats causing this restriction by examining it off the car.
Well latest update is that we think we are finally onto something and might get all this sorted out. The intercooler was pulled off and tested, it was perfect. What we found was that the 3.5" metalcat had its internals all melted due to a very rich tune n trackwork and was causing a big blockage. The cat has been replaced and the car will be going onto the dyno tomorrow to confirm if everything is sorted out or not. Hopefully thats the end of all this boost drama. I cant believe after all the time checking n changing hoses n checking everything under the bonnet that it mightt possibly turn out to be the cat giving me problems.
Yeah well hopefully its all sorted out tomorrow, but sheesh this was surely missed from the start, what a bitch having gone thru so much checking. That was prolly why the car was driving perfectly fine i guess. Seems like the MetalCat can't handle too richly-tuned track gtrs. It just lasted me slightly more than a year :( I think ill just go de-cat on the circuit. :P
Yeah well hopefully its all sorted out tomorrow, but sheesh this was surely missed from the start, what a bitch having gone thru so much checking. That was prolly why the car was driving perfectly fine i guess. Seems like the MetalCat can't handle too richly-tuned track gtrs. It just lasted me slightly more than a year :) I think ill just go de-cat on the circuit. ;)
Wouldnt it be a too lean running GTR? As the car runs leaner, the exhaust temp increases. As the car runs richer, the extaust temp drops. Or have i got it wrong?
Rhett
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
