Last week i took my non turbo r33 skyline to a mechanics shop to get the timing belt changed, spark plugs ,fuel injectors the lot done.
i handed the car over on wednesday and the mechanic said it would be ready by thursday,come thursday not ready..
i go in on friday and theyd done all the work, but the pistons wer not turning properly so i had to leave it over the weekend.
and so today i whent back and the engine is fkd! one of the pistons hit 'somthing' and i need to get a new motor!
basicaly i need advice from anyone who has a clue, the mechanic claims that this happens alot to no.4 and 6 cylinders in skylines, i smell bullshit but i cant argue, i drove it in there no worries and now its rooted, they claim to have checked it all before starting it and then when they started it there was a massive clonk sound , its too much of a coinsidence that it fkd up there and then....
so does anyone know if that actualy is a problem with skylines,or is it the fact that the timing belt wasnt installed properly or what?
so any help from anyone would be very muchly appreaciated!
thanks
https://www.sau.com.au/forums/topic/170385-need-help/
i wouldnt be able to give you extremely technical advice on this, but i reckon that is complete shite...
you may be on the ball assuming they havent installed something correctly and have caused the problem, but proving it is another thing hey. Maybe have it towed to another mechanic who works on imports quite regularly.
https://www.sau.com.au/forums/topic/170385-need-help/#findComment-3146679
hey glog sorry that had to happen to u
i showed a mate of mine and he loves his cars, he says the mechanic didn't instal the timing belt correctly and the piston hit the valve. hes pretty sure thats wats happened judging by what he has read.
hope all goes ends up going well for ya
https://www.sau.com.au/forums/topic/170385-need-help/#findComment-3146702
sorry to hear that this has happened to you mate....from what i can read about it i think its the mechanics fault....i only take my car to trusted import workshops/garages.....where my mates have gone before and a place where they also have a very good repp
https://www.sau.com.au/forums/topic/170385-need-help/#findComment-3147722
worst case seek legal advice. im pretty sure you got something to go on. car was fine before service now its dead. maybe get a report from a reputable workshop that can diagnose the problem that it could only have happened due to the work done on it...ie timing belt not installed properly for the 100k service you paid for.
good luck on getting it fixed. hopefully they're decent enough to admit fault and fix your car.
https://www.sau.com.au/forums/topic/170385-need-help/#findComment-3149417
Try to take your car out of there if pos. Thake it to a workshop you can trust , get them to take the cyl head off and give you a report as to why it happened . Armed with that go to fair trading and see if you can get them to pay for the damage .
At a guess I would say they mistimed the belt and when they tried to start it a piston or 2 hit the valves and bent them .
It's not rocket science, all you have to do is line the cam gears with the marks and at the same time the crank gear with its mark as well.
https://www.sau.com.au/forums/topic/170385-need-help/#findComment-3149993
sounds likie the mechanic did a quick job and didn't line up the cam gears properly... everything needs to be turning at the right time or shit crunches into each other.... that's why the cam gears have markings on them.
the pistons are all the right length etc, and dont just "hit" things without being in the wrong place at the wrong time... that's why they call it a TIMING belt... its made specifically to TIME the pistons!
dont let them near it or at very least be there when the cover is taken off and take a photo, if they marked the belt in any way, which is common, you will be able to see if things dont match up. even if you cant tell a qualified mechanic will be able to tell you
sorry to hear...
i feel your pain, my 33 was hurt from a similar prob... mechanic crossthreaded the tensioner pulley for the cam belt and it broke under load, luckily the belt stayed on! still ran me $882 though!
https://www.sau.com.au/forums/topic/170385-need-help/#findComment-3152178
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
