hey guys,
Im trying to modify the wiring on the std boost solenoid in order to get full boost ... I read the DIY thread but it was a little unclear..
I was wondering if someone can explain it to me in other words.. I'm a little confused as to which end of black wire (ground) i should be grounding. and also it also talks about a lead wire to the black wire ???
I know I sound pretty hopless and i would appreciate any help ..
https://www.sau.com.au/forums/topic/170390-high-boost-with-stock-solenoid/
if your unsure, why not ground both ends? or leave it, run your own wire on a switch through to a ground... then you can choose what you want :O
best idea is to cut off the plastic around the wire (not easy to do) connect your own wire, run it into the cabin onto a switch, run the otherside to the chasis... thats what ive done, its wicked :)
but what you could do if your unsure about which one to ground, start the car and try grounding one end... you can hear a click if it works...
have you already cut it?
yes... but you need a switch on that too...
your basically making a T with the wires... when the switch is off, it will act as normal, when its on, it will be in high boost mode...
so connect your wire to the stripped wire, run your wire into the cabin to a switch somewhere, mount the switch, then run the wire off the switch onto anywhere on the chassis...
get it?
and make sure to clean up everything, dont leave any exposed wire anywhere...
to wherever you wish to mount it...
find a place thats out of sight but still easily reachable...
there are a few switch houses on the dash near the steering wheel that were never really used... use one of those...
i know a place where you can put 5 that no one else has thought of yet... but thats my thing :woot:
geez you're secretive Doof. :woot:
just-drift-it: stick your head under your dash there are brackets all over the joint. i mounted my switch on the right hand side in the coin holder. the closest bit available for me is a bracket for holding one of the relays under the dash. even had a convenient hole for me to bolt a washer crimp thing onto
where is the best place to run the wire into the cabin from the solenoid??
On the same side of the engine bay as the solenoid, but on the firewall, there is a rubber grommet thing that probably already has some wires running through it. If you run the wire through there it will come out in the passenger footwell. I found that a wire coat hanger helped pull the wire through.
with this grounding solenoid stuff, i just ripped it off completely n ran a line straight from cooler pipe to actuator, never had any dramas, that was 7lb all day everyday.
Cool so this works does it?? so you bypass the solenoid completely and run off the actuator. its better this way i guess so you dont burn out the solenoid but is it safe?? any opinions
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
