hey all.
im about to purchase a hybrid(HDi) fmic kit for my 25t.
the biggest concern for me is that i dont want to have to trim the fan blades of the visc. fan. is it possible to NOT cut the fan and just run it a lil higher?
Kinda urgent as i will be getting it in a few days.. if i have to cut the blades then i wont get it.
https://www.sau.com.au/forums/topic/170401-hybrid-brand-intercooler-questions/
hey all.
we fitted a hybrid intercooler kit on a r34 at work ,they made the top pipe all wrong, we had a bit of trouble with it hitting the fan on top an the side, so i welded an extra 30mm of pipe to make it longer,as he never wanted to buy a new pipe,it hight have been a one of thing,an yours is a r33 (so may me a little dirrerent again)but some thing to look out for
y dont u get the pipeing that come back up through the some side that way u will have nothing to worry about
i got the same kit for a 33gtst and you will have to cut the fan blades unless you do what BAMR33 said and muck around with it and mount it higher. If you do this then the mounting points might not line up so there are a few things to consider. you can also get a new pipe made up for this bit and use other pipes that come with the kit but thats more expense.
yeh i would love the stock return pipes but a cold air box wouldnt fit at all..
i just hate the idea of chopping up the fan
i only had about 3mm come off mine,but i never had a hybrid kit though,wae never cut it just started the car,pushed the pipe down a bit
i take it you dont live in synney
hmm so i can mount the pipe a bit higher but just have to secure it.. thats not a problem.. but would the cooler mount up if i move the pipe a bit? how does that affect the fitting of the cooler?
sorry iv never installed a fmic so dont knw much, thus the newb questions, and yer i have searched for days.. couldnt find the hybrid installation guide which was on here.. so yer >_<
i had the same sort of questions when doing mine :laugh: was very lost on how to do it. with mounting the pipe higher you have to check that the bonnet wont push it back down or move it when closed and be pressing against it all the time. In terms of the actual cooler it might be that the pipes are at a different angle a bit so make sure they are in enough and secure as you dont want them blowing off when you driving off but cooler should be able to move from side to side slightly anyway before fully tightening.
I have the pipes returning to stock in/out.
But on a mates car, I just aligned the pipe work first and then positioned the intercooler after. With the silicon hoses there is a little leniency for difference in installation so don't be to worried. Just trial fit over and over until your happy and ready to cut the hole in the inner guard.
are you using one of those coolers where both the inlet and outlet are on the same side? or did you use a standard front mount and make custom piping run under the cooler and back up to the stock pipes?
yer its one of the coolers that use the over the radiator setup...
my above post was for BAMR33 lol
yeh the one you got is the standard front mount kit, some people had to trim there blades and others did not, just try and move the piping back alittle and secure it there as others have said. >_<
No, I just bought a normal opposed entry/exit intercooler and made up my own SS piping. Happy with the results, but I'm now considering upgrading to a big (at least 100mm thick, custom end tanks etc) side mount intercooler with shroud and supporting water injection just for something different.
If your really worried about the fan just get a greddy spec-m they are about the same price. No trimming required.
the Hybrid kit is costing me $620 NZD delivered. i dont think the GREDDY will be a similar price?
Just chop away !
It must be the 1st and last time i ever used the chicken cutters out of our kitchen knife block :/
If you get stuck mucking around with the fitment, it really isn't worth the worry. Just chop em, feal a bit bad for about 2 days of the slightly/un-noticable/untidy bits under the bonnet and then you'll be, what was i worried about!
But you can chop em and then use a file to round off the edges to neaten it up a bit...which i should do
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
