The stereo has been in the car a while now, and all of a sudden I have noticed that there is a sound dropout. It happens every now and then and is beginning to piss me off. I will start the car, and it sounds as if there is only sound coming from the rear speakers. It may take 5 minutes or half an hour and eventually the system goes back to normal.
The system comprises of components in the front and 6 x 9's in the rear run by an Audison amp, and two subs in the boot run by a cadence amp. I had pretty much the same system in the old skyline and I have disconnected and reconnected cables but to no avail.
Any ideas anyone?
https://www.sau.com.au/forums/topic/170428-sound-dropout/
i'd back the amps matie .. whatever is powering your front splits is having issues ... orrrr I know its a weird idea but your cones have dust one them .. check!! sounds weird but can seriously stop ur doof going doof .. has to be only about 1mm thick
also check your head unit .. see if wiggling the wires which connect to the h.u turns on the speakers.. then u might find ur problem
Edited by DECIM8
https://www.sau.com.au/forums/topic/170428-sound-dropout/#findComment-3148880
didnt you say in the first post that you disconnected and reconnected the cables?
well that includes earth cables... so if you have already done that, then i would suggest no... again...
but if you haven't done that, i would suggest going over your wires... again... for the first time...
is it a sudden pop and theyre working again? cause if it is, its a wire somewhere... or whatever amp is running them is going into protect when you turn the car on, then waiting to come out of it...
most likely cause of a LOOSE WIRE...
https://www.sau.com.au/forums/topic/170428-sound-dropout/#findComment-3149292
Dont get emotional. I did say I checked all the cables. Not the wires eg earth. Again... dont get emotional.
https://www.sau.com.au/forums/topic/170428-sound-dropout/#findComment-3149359
you make me cry :P
wires/cables... they're the same thing...
again... you make me cry :'(
Wires and cables being the same thing could be argued. Anyways, I'm only shit stirring hey. When I checked all the wiring/cables, I was referring to mainly RCA's and cables to the amps, speaker cables and head unit cables. As far as I can find there is an earth cable which runs from the head unit, and as the two amps are connected I think there is one earth from them.
As I never installed the system, I should probably just go to my installer but I was hoping to try and figure it out myself.
https://www.sau.com.au/forums/topic/170428-sound-dropout/#findComment-3149661
psh, your boot install is better... thats about it i think :woot: STILL haven't met you...
but yeah, its a weird problem... if it is just popping back on instantly, then its either a loose wire or the amp is in protect, cause of a loose wire... Wish i could have a look at it, but im betting its one of those... dont think its your gear...
that ground running from the head unit you speak of is the remote wire for the amps... it tells them to turn and off... its a constant positive feed, dont know how strong, but if its exposed somewhere and hitting the body of the car, then it will turn the amps on and off intermittenly...
DECIM8: Im thinking about dropping 2k on subs this weekend... you STILL gunna have a better system then me then? ;)
https://www.sau.com.au/forums/topic/170428-sound-dropout/#findComment-3150688
Hahah 2 K on subs .. wasting it .. I got my Fusion NV comp series for $300 and it shakes buildings apart... Not to mention my poor boot..
Wait im a lier .. Unless your dumping it on some JL series or somthing? Id love to hear that .. W7 :worship:
I hope you got some serious front setup to match .. I wanna install those crazy lil vibrating things... Haha just for the chiqs bro hahahah
My boot install is crap im going to rip it out and start again for the 3rd time .. to hard to please
I wanna see ur install!
https://www.sau.com.au/forums/topic/170428-sound-dropout/#findComment-3151130
Wait im a lier .. Unless your dumping it on some JL series or somthing? Id love to hear that .. W7 :yes:
My install is what we in the profession call... "temporary" :worship:
i have some powerful MBQ for front, and some alpine Type S for the rear... i still need to amp them, but they will be getting 100WRMS each when i get my ass around to doing it...
theres nothing special about my install as of yet, im still thinking up a decent and original design... i have a few ideas, but space appears to be the biggest problem...
and no, its not JL... the subs im getting are rated at nearly twice the power output of the 12W7... and its not some gimmick either...
see the 'danger zone'? thats the comfort zone for these subs :banana:
PS: they cost $1k each... but im getting 40% off... no one who is serious about this pays shelf price :3some:
https://www.sau.com.au/forums/topic/170428-sound-dropout/#findComment-3151227
yea thats right, if the fuse blows it wont turn on, i didn't say it was blown, when you test for condinuity on a FAULTY fuse, it has condinuity sometimes and sometimes its a broken circuit... i.e. his dropouts of sound
you must really love your bass to pop a fuse LOL
https://www.sau.com.au/forums/topic/170428-sound-dropout/#findComment-3151231
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
