i've popped a boot before... what does that mean? :cheers:
HAHAHAHHA ur crazy
I run 3 fuses to avoid blowing it all .. and also to get the amps to power individually.. :dry: POWER!
I popped one a current got far enough to take out and cut the second one .. dunno how that works tho :D
Wheres ur boot install tempory my ass shoooooooooo me
HAHAHAHHA ur crazy
I popped one a current got far enough to take out and cut the second one .. dunno how that works tho :cheers:
well you cant really run a fuse on a boot :D
and i run less amps then you it seems... yay for f**kin powerful monoblocks!
do you run three independant fuses, or 3 on the same line?
temporary as in... no...
its an old box i had lieing around, chucked it in the boot, tied it down... for the longest time i have been trying to design a decent way to get 2 very powerful 12 inch subs in there, in a duel slot ported box that still has the required literage, and so i can still get to the battery...
any designs i came up with just weren't up to scratch...
so 2 12's it is... and probably sealed boxes too...
lol crap me dead from the sounds of it thats going to be big .. sealed boxes .. Ill help ya out if you need it .. I can use a drill and wreck stuff really well.. trust me ..
Reinforce the boot hey :dry:
I run 0gauge with a fuse in it and then split into 4's to run each amp .. seems to work well :D
Im going to run two 10" in the boot too and rice it up with some nos bottles woot
Oh and I run a 2000rms mono :cheers: and v series to power the split sensation that tingles my passengers ears
Edited by DECIM8
Reinforce the boot hey ;)
could always use another pset of hands :D
and yeah, but how the hell do you go about doing that exactly?
lol, nos bottles :dry: cut out the bottoms and put speakers in there :D
3kw... does that make me the winrar? :domokun:
I just use it to blow skirts off the gurls and make the old people look young again .. Boom boom f**kers... I never turn it up full blast id lose my hearing .. not to mention blow my winscreen out :@
3kws .. wow thats some nice shit but whats your subs run at :D But im the winnnn na na :P RICE SETUP RULES :@
Ive got the weekend off im going to tackle my box this weekend I reakon .. How fun is it trying to get a big mdf peice in a R34 .. NOT VERY :@
And running dual amps on different power lines is easy .. U just buy a spliter it it a divider which seperates the lines with two fuses in each line then u run a smaller guage out of it to each amp .. protects the amps and also gives them there own power supply .. they suck what they need..
I need to install a cap any idea how to do that .. suppose I should buy one first :|
Edited by DECIM8
Most of the system was in my old line except for the audison amp, and the headunit. The earth wire coming from the headunit is simply has a connector on the end of it which goes under the tightened screw of the side brackets of the headunit.
yeah i still do all that :P but im not normally IN the car when its up that loud :(
the subs will be rated at 2.5kw... ive had this planned for a while, i just finally have enough money for it :D its gunna be crazy...
im gunna put my car in the shop for a week, starting monday night... got a lot of stuff to do before Show N Shine :D which you had better be entering!
yeah i know, at the moment, i have had to use 2 distrubution blocks for power coming OUT of the amp to the subs :)
capacitor is easy as... youll figure it out in about 10 seconds :P
I dont think you understand the idea of show and shine... its mostly just to chill with mates who have the same car, learn a thing or two and such...
this isn't auto salon man... im entering mine, and its got piss all... hell, people are entering completely stock cars, some worse then that, and i even know a few who are entering with drift damage...
we actually have a chance to get the most number of skylines ever together in one place... it would be a world record... we can do it :D and we probably will...
oh, and the president of the club himself will be keying any skylines parked in the car park... even more incentive to enter...
seriously, you own a 34, so by default, your car is better then mine already :P i HIGHLY recomend you enter, and that you tell everyone else you know with a skyline... its local, and its $10... its gunna be a great day :)
and yeah, the cap is seriously power in, power out, and ground... thats it... it just stores power before going to the amp...
where you put the fuse is the tricky part :D
but yeah, a guy like you will figure it out in 10 seconds...
a guy like me... 5 :D
yeah screw rims... i was gunna see if i could borrow some from a store, but i couldn't be arsed :(
oh yeah, the guys from ignition are gunna be there filming... and so will HPI... so if you wanna get on a DVD or two, i suggest you come :)
its gunna be one hell of a day! :P
    • The easiest option might be to just spray a bunch of fish oil in there.  At least that way you can feel like you've done something while you continue to ignore it
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
