TD 42 and td petrol use the same bottom end dan. the 4.5 and the 4.8 petrol jobs are also the same aprt from bore and stroke.
If you are gonna do it grab the 4.5 petrol number. Its a free 500 cc. The 4.8 would be the killer given that it already has the right head but its a bit thin on the ground.
Yeah but the TB45E has a bore/stroke of 99.5/96 whereas the TD42 has a bore/stroke of 96/96
The 4.5 will not rev as high as the 4.2 and the rod length/stroke ratio is right on for maximum torque and still being able to see 8k rpm.
I'm picking up the GT51R at the end of the financial year. :sorcerer:
  • Replies 222
Posted Images
well screw you all im building my dream xp falcon after the cefiro is finished, it will house a twin turbo 347ci small block ford than will make rb's tremble at the knees.
Ford...snicker snicker. tee hee. Oh fucit. ROFL
Yeah but you asre forgettng something very important....at the end of the day.....
when all is done.........
and everyone has left.........
it's still a bloody FORD!
yeah sorry i can slot a hemi in there, not quite enough room.
go check out the trick and mansweto (sp) capri and tell us if a small block chev can crank like that thing
Quite sure. Mouse thats m.o.u.s.e. The rat family are the big blocks. Mouse motors are small blocks. Ya wanna rev get a chev. :P
dude i may be young but i know more about the old stuff than any thing else, and nothing revs like a small block ford.
but people have been having this same disscussion for more years than i have been alive and its never been settled so lets agree to disagree.
^^^^^^^ford power^^^^^^^^^
Agreed. :P
Agreed. :P
see who said that the qld section needs moderating when there is gentlemen like noel and myself around
by the way RB20 RULZ !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!11
    • I'm keen for this content to 😂
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
