ok i am looking at getting a safc! will these be good to help tune my car? i have herd there a good little device to sorta substitue the pfc!?
also anyone know how to swap a rb20t with a rb25t on a rb20det? as i have one to do!??
and how long does everyone warm there cars up for?
cheers adrian
https://www.sau.com.au/forums/topic/170469-looking-for-some-ideas/
I've got a SAFC II on my car, they're perfect if your running a little bit extra boost and dont plan on making big power. Before I got mine I was running 12psi with a really rich tune making 155rwkw, after SAFC got 170rwkw just by leaning it out also saved on fuel big time.
As for changing turbos they both use the same oil lines so its a straight swap may need to modify the dump pipe tho
And for warming up my car I let it run for about 30 sec then drive without going on boost until the temp gauge is up
hope that helps
cheers adrian
This was answered before...u need to work out your future plans for mods on the car. SAfc is a piggy back and will only let u adjust so much.
If u want more power later, u will have to sell it and buy a pfc then. Its not a substitute at all.
Tirbo should be straight swap.
Warm up the car as Tuffr32 said.
R32 remap can be done by Jeff from The Speed Lab. ns.com users all rave about him, have no personal experience. He also did a big thread on there about it in the Forced Performance section. Give him a try, often can work out cheaper and better than an SAFC on the 32's I believe.
    • Small update for the day... Turns out the intercooler and engine coolant hose kits are anything but complete....I probably should have counted better but it only really covers about half the coolant hoses in the car, it really just covers the visible stuff and pretends everything else doesn't exist (turbo water feed and returns and also heat exchanger lines through the 2 pumps and cooler) .In any case, I'm happier to have half reliable hoses than none, but a bit of a disappointment. Anyway...finger click (and 5 hours).....hoses in place, lots of spring clamps replaced with screw clamps, and engine coolant is on the pressure tester for the night.   Incidentally, upsized header tank is an Inifiniti factory option....not sure I'll ever do prod car racing in this but at least it is legal.
    • Just weld it onto the hot pipe. If you want it right after the turbo, put it right after the turbo. Or rip the comp cover off and drill and tap a hole into it.
    • hahaha glad I can rely on you two to go on a spiral at the drop of a problem! Some quick answers....the ducting is excellent top bottom and sides....everything that gets in goes through the coolers (noting the oil cooler redirects it out again, fair call if it is cooling 120o+) and the heat exchanger for the intercooler also has some scoops to pick up more than it's fair share too. I can't see going down the water spray track....no bueno for formal racing and a big risk for long rally days if you run out (plus I'm not clear if it is allowed there either yet).   Frankly, it must be possible to reliably put 400kw through a standard front end, the BMWs do it so I just need to work it out....I'm starting with reducing blockages in the way and adding some coolant capacity with a bigger header tank, flushing rad and making sure it was filled/bled properly (I didn't do the last coolant change); also taken measurements incase next step is a bigger/higher capacity custom radiator
    • wow, a completely stock GTR! I've got to admit, I have no idea from what you are describing....do you have  any idea where the "thump" comes from, and are you certain it is the HICAS light not something else like the cat overheat light?
    • nice work, welcome to the world of CAD! fabricating accurately in 3 dimensional space is beyond me....I almost always end up making something more than once...sorry I mean I extensively use prototyping
