How Old Is The Average Sauer
172 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hi,
It has crossed my mind, the thought of how old everyone on here really is.
So I thought I would try and find out. I have included a Poll so we can all see the results.
Thank you,
Regards
Edited by paulr33
https://www.sau.com.au/forums/topic/170497-how-old-is-the-average-sauer/
  • Replies 40
so far im the only 1 under 18? :(
If you already own the 33, i hope you get your licence b4 1/07/07 :P
I guess even if you do get your licence b4 1/7/7, you run the risk of a $1100 fine and 3 dimerit points, for every time you get pulled over, for the next 3yrs :/ .
hes got a non turbo sedan if my memory serves me correctly.....
but hate to be those 18 year olds that will be getting the fine and loss of points for the next 3 years! good luck to them
yeah mines a not a turbo, only reason being what you guys have stated, $1k fines every time i'd get pulled over. Although even with a non turbo once ive done some mods to it the cops will most likely pull me over anyway to check it and i can laugh in their face.
Oh and getting my P's 18/07/07 hehe.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
