In a recent rego inspection i was told of a couple of problems i have to fix. Most of them i have covered but there's a couple that have me stumped.
Firstly, engine mounts have to be changed. Car is an R32 GTS-T. Is this a hard job? Am i right in thinking the whole engine doesn't have to be copmletely removed?
Secondly, leaky sump gasket. Can this be done with engine and crossmember in place?
Also, as far as i'm aware there is no actual gasket, its a chemical sealant. Would Permatex Ultra Grey be the right stuff for the job?
Cheers guys
Simon
Cheers guys
Simon
Simon did they give you a reason why the engine mounts had to be changed eg: they were cracked???
To change them you will have to lift the motor up (shouldn't have to come right out) along with the box using a crane and change them over whilst its up.
You can get to the sup easy enough with the car on a hoist and x-member still in place or with it up on jack stands :D
GMB
They gave no reason why they need to be changed. I haven't had a look yet but if i can't see anything obviously wrong with them then i'll try and avoid changing them.
As for the sump... that's good news! :D Any tips for doing the gasket? I never had to do one with a sealant before... only ever used gaskets.
If the sump has been leaking, it's possible the engine mounts have been affected by the leaking oil.
I suspect you are going to have to lift the engine a bit so you can manoeuvre the sump around the oil pickup. If you've lifted it up (and disconnected the mounts), may as well replace them.
Probably the most important point is that the surfaces must be CLEAN. So lots of clean rags and gallons of metho. And a tonne of patience.
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
