Hey everyone.
I didnt really know where to put this i just decided to stick it here. I seem to be having a little ant trouble with my car. They are all over the body of it and my guess is that they are walking up one of the wheels and the climbing up some how. I washed the car yesterday in the hope i would kill them all and then parked it in a different spot and they still seem to be hanging around.
Has anyone had a problem like this before?
Anyone know what i might be able to do? I just dont want to mess up my paint.
Al
https://www.sau.com.au/forums/topic/170530-ant-invasion/
Hey everyone.
Al
They hang around because they like you. No not really.
They actually nest in the car. Happened to my pulsar when I had it.
They used to eat my chewing gum.
I'd go to have a piece of gum and it'll be all munched on already.
https://www.sau.com.au/forums/topic/170530-ant-invasion/#findComment-3149036
Just normal car wash. I cant tell you now cause its at home. Yeh i think they came up on the tires and then on the suspension.
My real worry is, do you think some sort of surface spray will damage my paint, especially cause its white and i dont want residue or shit on it.
I dont thik they are nesting in my car. At least i hope not.
https://www.sau.com.au/forums/topic/170530-ant-invasion/#findComment-3149207
hey mate ive never had an ant problem in my car before, but can tell you that these ant baits are probably your best bet, even over some sort of surface spray or similar...
Whenever I have an ant problem at home, I use Ant-Rid liquid formula.. looks and smells like honey... and basically wipes out the entire nest as the ants take it back to the nest with them...
the only thing with it is you will probably end up with a few ant carcasses here and there... I think the majority die in the nest, because I never seem to see as many dead ants lying around as there were feeding on the stuff... so this may be a problem if the nest is in your car..
anyways website -> http://www.antrid.com.au/products.asp
can be bought from most supermarkets..
good luck.
https://www.sau.com.au/forums/topic/170530-ant-invasion/#findComment-3150394
make sure they dont nest in your car... i work at a honda dealership and one of the cars had a problem and just wouldnt start anymore.. the ended up pulling out the ecu and opening it up and guess wat they found in there??? an ants nest... let me just say that it was very expensive for the customer
https://www.sau.com.au/forums/topic/170530-ant-invasion/#findComment-3150601
Hey everyone.
Al
What a stupid avatar.
you're dead to me..
Edited by Driver
https://www.sau.com.au/forums/topic/170530-ant-invasion/#findComment-3151116
I had this happen not to long ago, removed some tree roots from under where i park my car then when it rained next it flooded the ant nest that had been using said root for flood protection. They were everywhere over the outside and in the engine bay. I used surface spray in the enginebay and on the wheels as for the bodywork everytime I went out for a cigie Id squish all the ants I could see. after about a week there was no more ants. And to stop them coming back a coverd my parking spot with ant-sand. Haven't had a problem since.
https://www.sau.com.au/forums/topic/170530-ant-invasion/#findComment-3153134
Hey guys,
I just found the next and there are shit loads of them. The nest is inside the passenger door. They seemed to have gotten in through the drainage holes at the bottom on the door and i am about to go jihad on their asses. Thanks for the help
https://www.sau.com.au/forums/topic/170530-ant-invasion/#findComment-3155671
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
