Hey researching for my new project, stock r32 for drift.
Does anyone have any idea on pricing for whiteline sway bars?new or used? :laughing-smiley-014:
Be throwing one in the front... and whether i should just go for heavy duty or blade adjustable..?
(please have mercy..)> :D:thumbsup::( (DESTROY!!)> :domokun: random*
https://www.sau.com.au/forums/topic/170547-whiteline-sway-bars/
For a thread with only 5 posts there sure is alot of confusion going on.
If you want a price on the swaybar you could always ring Whiteline & ask them. Or your local Repco or similar sttore as they sell them.
If you want to help your car drift putting a stiffer sway bar on the fron will help it - undertsteer.
If it is an R32 GTS-T the cheapest thing to do is get a rear sway bar off a GT-R.
If you must have the Whiteline gear get the adjstable bars.
http://www.skylinesaustralia.com/forums/in...showtopic=85591
Stiffer front swaybar without an upgraded rear swaybar will work miserably for drift, definitely get the rear one first. You'd be much better off getting both at once though. And having them adjustable is quite helpful.
Quick question:
Will you notice any difference if you get two different brand sway bars?
I currently have custom made Kmac rear sway bar.. But might get whiteline for the front (due to cheaper pricing)
So should i go back to kmac n get a front one made up as well?
I'm gonna go with blind :worship: joke. Doesn't help that the site now reduces the size of all the pics now though.
http://image-cache.skylinesaustralia.com/f...ine_Package.jpg
They're called stabilizer bars in the price list. Swaybars = stabilizer bars = anti-roll bars.
Siddr20: I doubt there would be a difference between swaybar brands. But ring up the two companies and ask them where they get their spring steal from. If they get em from the same place, they're gonna be pretty damn similar.
Edited by salad
The particular source of steel is not important. The diameter(s) of the sway bar & the length of the lever arms are the important things. So check the outside diameters & the inside diameters also if the bars are hollow.
Sorry, my mistake, I made a couple of assumptions there, just thinking we were comparing brands. Checking the diameter is a must when buying swaybars, I dont think there are any Australian companies that make hollow swaybars though, so that makes things a bit easier. Arm lengths dont have to be worried about too much as they have to be kept pretty constant to fit the car.
(please have mercy..)> :cheers::D:dry: (DESTROY!!)> :domokun: random*
hey i got new front one you can have it for 100, it is the adjustable type. Left over from my RB26 conversion.
it funny actually as i pulled a full set of cuscos out to fit whiteline ones to the S13. Thw whiteline ones offered a better solution and worked better. They are heavier though.
get the largest gtr rear one and match it with mine and you will be laughing (i left my laptop at home so i dont have the whiteline part numbers in front of me)
i found when i had my R32 that a 24mm (i think) rear sway was absolutely insane for my car drifting........had coilovers and section front and rear camber arms as well, but once the sway was in with just a standard front any corner and the tail would come out with minimal effort. found it nice for my style driving
I can 2nd that.
I have an R32 with the following suspension.
whiteline springs and unknown shocks
front castor arms
whiteline adjustable rear swaybar set to medium.
the car drifts like a champ. :P
no front bar needed.
  Nathan_G1 said:
its all about the "grip" with you Salad.............LOL
-personally i think each to there own, comfort is more important then what people "say" you should have based on there experience.
In any motorsport your aim is to maximise grip... So what's wrong with trying to get more grip?
Comfort? I dont think so with your 14/12 kg/mm springs :blush:
Edited by salad
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
    • Ha ha ha, so they stopped the bearings spinning on the one you want, but then decided the crank hub should slip instead 馃槢   Stick to RB, at least you can work on it yourself. And now it doesn't smell of vapour   Also I still believe there's a chance your new flap doesn't "pop", as even though the engine might breath hard, it has a direct path with no restriction to the inlet, which when on boost should pull a bit of suction for you. If you do get pressure in the catch can id be very intrigued. Time to put a boost gauge on it, and a session at the track, then solid cover your vent and do another session
    • Oh nah, S55 doesn't eat bearings, just the crank hub slips lol.
    • When鈥檚 the tow ball on the 33 coming? 馃檭
    • I welcome any basic question that can help haha. Yes it has 2 unis but the driveshaft is a one piece and the unis are welded without a slip yoke at each end.   What's funny is anytime I've ever had wheel vibrations it's always been in the front so I automatically assume it will lead to steering wheel shake and not chassis vibration. With that being said, I never considered looking at my rear wheel balance... I have doubts though as this wasn't an issue before I pulled the motor and trans but is still very much worth a look. I'll do that tonight after work. Thanks.
