how much did it cost you, if you dont mind me asking...
gates racing belt $110
coolant $30
fan, alternator, waterpump belt $50
idler, tensioner, cam seals, front crank seal $260
labour $100. was a friend who done it for me so i got that part cheap
so yea i got away with it for $550
Yea how much? Also i spotted u melton freeway and calder park drive last night... You had a statesman behind you at lights.
yea was bored went for a drive. what stato wer u in? i ran a vn bt1 shortly after :P lol
Edited by R33GOD
I wasnt in stato, i was in skyline(white 33) You went up inside at lights before that intersection ^ and i was in far lane... then i turned up calder park drive, statesman was behind you driving like a hero through traffic.
same place i spotted you last time
was it a new clubby? i only remember that going up my ass bein a hero
  • 1 month later...
coolant $30
hey man, what part numbers did you use for these? they're 3 different belts right? did you do the power steering belt too?
only reason i ask is i'm probably gonna get lube mobile to do my 100km service and just supply all the parts (a workshop quoted me $600 for the labour). I just want to have everything there ready to fit.
Will probably also take out the radiator etc for the guy to save money (he can put it back for me though :() just don't want to have to guess with things like the timing and tension and don't have a harmonic balancer puller.
Aww this reminds me its time to do my 100,000km service also. Just emailed Unigroup for a price fingers crossed its not too crazy. How long did it take to get the whole service done?? Did you get the car back the same day??
Edited by LatinR33
it's usually less than a days work. actually no more than 4 hours for a mechanic (tops) otherwise you'd have to question their skill level. but that's just for a fluids, belts, water pump, idler bearings etc change. if you add in extra stuff it'll take longer obviously.
Just got a response from Lube mobile they said this. Its a little bit excessive I think.
"In response to your e-mail, the labour to perform the 100 000km Log Book Service (Including fitting your Water Pump, Timing Belt and Tensioner). is only $588.20"
that's pretty good!
all lube mobile did was tell me is:
LM "To get a mechanic onsite to do this for you you would be looking at our minimum charge of $132.80 for the first 45 minutes and $99.80 per hour thereafter."
ME "Any indication of how long this type of job would take?"
LM "The mechanic will be able to give a better indication onsite."
which i thought was pretty lame, but they called me after i said "why not just put those prices on the website then!?" and she said I wouldn't have to pay for anything if he came out and gave a quote that I wasn't prepared to accept.
Thats the good thing :thumbsup:
You know about the work I had done, which he completed at 7:30 last night. The "worst case" quote he gave was $2500, I ended up paying $2400.
This was the major (all fluids, flush, belts [timing etc etc], tuneup, clutch and brake master, new plat plugs and gapping, a few hoses, and so much more I couldnt list but just think "
the major of major services lol), steering pump, 2 x Nolathane castor bushes, fuel lines (f'ing thinks were ripped up and leaking everywhere haha - why i drove it like this, I dont know haha), wipers, 02 sensor, water pump.
Plus they gave me 2 x $30 vouchers for my next service haha.
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
