This car is absolute immaculate condition the car is unmarked. i am an skyline enthusiest and no cornet have been cut in building this car, all parts used are quality brand name japanese parts. This car has been featured in many car shows such as autosalon and has been featured in certain car magazines
The car features the following modifications and accessories:
- APEXI AX53 B70 Upgraded turbo
- Front/dump pipe/high flow cat
- BLITZ NUR-1 3.5' catback exaust system ($2000 S/steel)
- APEXI shockers
- HKS Adjustable Suspension
- BLITZ turbo timer
- BLITZ Boost controller (not fitted) currently running standard psi of Apexi turbo
- Excedy 5 puck button clutch (2,000kms old)
- Custom Polished front mount intercooler
-Custom Steel air intake pipe and Apexi Pod (have standard airbox aswel)
- 100,000 service just done, cam belt and pulleys changed
- Autometer guages
- Full body kit with R400 front bar
- MEK 18 inch hyper wheels with new tyres all round
- Clear gtr indicators
- Custom flat boot lid
- recently full resprayed in custom blue (immaculate no swirls or marks)
- Cd/MD double din player
-Alarm and immobiliser system fitted
- serviced every 5000 kms with motul turbolite 4000
- Rego till SEP 08
This is my pride and joy and only gets driven once or twice a month, the car never gets driven in rain. Genuine enquires only please no test pilots thankyou.
Please call for any information regarding this car
$17,500.
car is real head turner runs like a dream great for crusing with heaps of power
will provide more pics but cbf right now
Alex 0403 019 923 Altona Meadows
Edited by XXX-33
im in vic to if mech sound would u be intrsted in
late 1996 series 2 nissin r33 skyline coup
ferari yellow over white
19inch cromies paid $4g for
racign breaks and suspentions
inside the car is like new
eng like new no leaks nothing
gtr injectors
upgraded turbo
racing batry
exsorst system
upgraded ecu
boost gauge timer
skyline imported racing rear sway bar
full body kit
clearion speacers
cd player
mech sound clean car
recpt for $20.000 from jsa imporst larst nov
+ over $8.000 since on lil mods ect rims
just wont sumthing that isnt as bright
comes with rego till dec
very intsrted iv spent 28g so far but i like couler fo urs
[email protected] is my email if intrsted
gtr injectors
upgraded turbo
racing batry
exsorst system
upgraded ecu
boost gauge timer
full body kit
clearion speacers
cd player
your car sounds tuff but its not what i want, sorry, i need the money, i dont want to sell the car but i currently need as much money as possible at the moment. thanks again anyway champ.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
