Hey all
Finally got around to doing some mods on the Skyline and just wanted to get some opinions.
Getting a 3' stainless steel exhaust system from the turbo back, been quoted $1800 or close to there from a few places, does this seem reasonable ???? Price doesnt bother me just want to make sure Im not being ripped off.
Also has anyone heard anything about a Microtech LT12 computer to replace the stock management system ?? They are atleast $1000 cheaper than the Apexi Power FC so was just curious to see if anyone uses or has heard of them. Apparently they do plug directly in with minimal work required.
Thanks
Scott
https://www.sau.com.au/forums/topic/17058-help-please/
as for the microtech im not too sure if there are guys running it here in perth but i know that a fair few do so in the eastern states. its best picking a respectable tuner and then ask him what he does best coz the engine management depend on how well the tuner is able to do it.
other options that wont break the bank are the Power FC and Wolf 3D. wait for the gurus to come on, they'll tell you more :D
https://www.sau.com.au/forums/topic/17058-help-please/#findComment-352884
My cat back system from jash @ c-red was around $1200, dump pipe was $180 and the front pipe was $150. The catback is japanese and was brand new, the dump pipe is made locally and new and the front pipe is a trust and was 2nd hand. Shop around and you should be able to get a good price, its the first mod you should do as the stock exhaust is very restrictive and only good for keeping the noise to a minimum :D
https://www.sau.com.au/forums/topic/17058-help-please/#findComment-352934
GTS-4OrCeD / G0DF4Th3R
I have only contacted local performance exhaust places, so I would think that it is not a jap system. Thought I would ask because it did seem a bit steep from what I have heard on the boards from other people.
Rob77
Do c-red do complete systems ?? or should I look to purchase some parts second hand ??
Thanks for the help guys
https://www.sau.com.au/forums/topic/17058-help-please/#findComment-352939
For a cat back system Try Works Auto in Bently they actually have a few Name brands in stock and have them hanging from the ceiling too! I dont think they are in the 1800, Was this place that quoted 1800 in the connoly area? Start with C? As for ECU the ecu is only as good as the tuner correct, but if your using the same tuner for all ECUS the best ecu is the one to have, Dollar for dollar it usually comes down to WOLF vs Autronic, Many will say wolf, im looking into Autronic myself.
https://www.sau.com.au/forums/topic/17058-help-please/#findComment-353192
Thanks for the help people, im heading down to c-red tomorrow to check out a system or two. Much better price too.
Munich, where was your mate quoted that price if you dont mind me asking ??
RB20lagwagon, thanks I will check out Works Auto as well.
The place I was quoted $1800, well there were two, one in Belmont and one in Vic Park, got a quote of $1700 from Myaree as well, but that was with a twin dump pipe.
https://www.sau.com.au/forums/topic/17058-help-please/#findComment-353971
    • I mean he could post them to imgur or the like and create a link. But yeah, spam bots absolutely will post pictures in their first posts.
    • Ah ok, reason I asked was for the sake of not having to upgrade everything if the turbo couldn't be capped.
    • pffft! My alignments are starting to take 3-4 weeks each. Bugger overnight - that would be a dream! Overnight is when I leave it on stands with the rear suspension in pieces, hoping I can remember where I was at when I come back to it. I have to set the car up on a level surface so I can get decent camber measurements, then try to set the RUCAs to the right length to get that right. Then I have to put the car somewhere else where I have enough room to set up the bumpsteer gauge (laser, paper, mirror), so I can dial out that. Then I need to go measure camber again because changing the tension arm length affects that also. Then I need to measure toe, and I can't do that to my own satisfaction at home, so I have to put it on an actual aligner. Then I have to go back and fix the camber again, and if that took more than a half a turn, decide if I want to set up the bumpsteer measurements again. I previously had the bumpsteer almost completely banished and then I started changing things again! And that's only the rear end. Not even gotten to talking about the front yet. And this has been going on in the context of me discovering a seized bolt in the LHR FUCA bush at the upright, hence needing total disassembly to replace that bush and the others that were not far away from the same outcome, replacing sphericals in the front end and making a mistake that resulted in needing to do it again, which is only half done right now. It's a selfmade nightmare. Only have self to blame, etc etc. But regardless, I am so complelely unable to utilise the services of a normal wheel aligner that I have no choice. I haven't found a shop in my city that does "race" alignments - and by that I don't mean I want my car to be set up for racing, but the set of adjustments that I have available and that need to be used to do the alignment are the same as you'd find on a race car. I haven't looked everywhere, but there doesn't appear to be the equivalent of the motorsport focused shops that are present in Sydney and Melbourne. And such an alignment would cost $300, and you only want to do it once in a while, and you don't want to find out that you have to replace bushes and bearings and such while you are spending that $300 so you have to come back and spend it again a week later. So I stay living in my self made nightmare for the moment.
    • Well, yeah, obviously. But then you have a turbo with 270kW "design", meaning it will have the higher boost threshold and lag of a bigger turbo, but only doing the work of a smaller turbo. That's the suck. That's actually exactly where I am right now, because my stocker exploded and I got Tao to do a highflow for me. I got a low pressure actuator on it and don't push it past ~10 psi or so, where the stocker was being run at ~12 psi. it makes a little more power than the stocker did, but it lags like a bitch. But, if I run any more boost it starts to ping and the ECU goes into panic mode, which cuts all the fun, so it clearly needs to be tuned. But, until such time as I (which is not I, it's my bro-in-law) can actually get the dyno working again, and get some injectors, and do all the swap over of those and the R35 AFM, I can't attempt to use the turbo the way it really deserves to. So what I have now is something that drives worse than what it did before it filled the cat with little pieces of turbine. I will tune it eventually, and probably only push it up to ~250-270 rwkW, which is pretty close to the max for that highflow anyway. I would imagine that by getting the tune right, and with newer betterrer injectors, we can probably make the boost come on a little earlier than it does now.** And if I do not think that the top end reward is worth the low end sacrifice, I will sell it off and convert to a G30, because the smaller ones of those come on boost very nicely on a 25 and make more power than I realistically need or want. The only reason I didn't do it at the time the turbo blew up is that I wasn't ready to sink a lot of money into an Artec manifold, reverse rotation turbo, the AFM and injector upgrade that would have been immediately compulsory, and the dyno was being problematic.*** It was easier and faster to just put the highflow on. And then, as I mentioned in an earlier post, even that is not "easy", because Tao's highflows use a shorter core than the Hitachi, so the compressor housing moves backwards in the bay, necessitating that all of the pipework had to get modded. ** And maybe just maybe, check the valve clearances and put new shims through, because I have recently seen firsthand on another motor that sloppy clearances on the shims can cost a lot of effective timing and lift and really slow an engine down. 3S-GTE in a Caldina got new shims, closing the clearances from just above the max to right down near the minimum, and it is a massively different car to drive. On boost the better part of 1000 rpm earlier!
    • ooooooh so this is where they get posted  Was at a wedding that day anyway, but the next one I will be there for SURE.
