does anyone here know what kinda bulbs are the R32 gtst using??
are they H3 or H1??
thanks!!
Jasper "generally" your low beam are H3C and high beam are H1 but it can vary.
Just take them out to double check and make sure, its only a 2minute job :P
GMB
oh..thanks!!
but do u have any idea whether do they have any "covers" over the bulbs when they are fixed in?
They are held in place with the spring clip, to protect them there is a plastic cover with a rubber weather shroud, takes about 2minutes to get to them all :P
I take it your not happy with the dull lighting that the 32 makes... its common for most imports to be like that so without upgrading to a brighter globe your gains are minimal if your just cleaning your headlight cover and realign them.
Have a look at getting a set of these from JDM concept and grab a set of Phillips or Narva H1's (about $20) for your high beam and that should sort it out :D
Cheers GMB
yea..the bulbs are kinda giving way as they are kinda dim at night..getting a hid kit from my home country this june!
Yeah standard bulbs are rubbish, i've never had the money to worry about HID so modified mine with the correct globes and its more than bright enough and cost me $65 instea of $500+ :cheers:
If your purchasing a kit just make sure its ADR approved (high/low beam) as there have been a few people questions about there's by transport :(
  • 3 weeks later...
they are ADR approved and i think that there shouldn't be a problem with the cops here..
Let me know how you go cobber, im interested to see how well the kit you get works and the overall difference with A/M globes :blink:
  • 1 month later...
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
