SOLD!!!
come and get it guys.
As topic says... i've spun a bearing but engine still runs and idles perfect, it's only when revved the tapping can be heard.
engine is out.
RB26 twin turbo engine comes complete with:
- turbos
- manifolds
- coils
- injectors
- new clutch
- new N1 oil pump
- new sump baffle kit
- all plastic covers
INFO - engine was reconditioned only 2500kms ago but over revved before running in properly(no rev limiter). therefore you should be able to replace the damaged bearing and maybe the rod, machine the crank and away you go. ive been quoted $1500-$2000 for the whole job. (i might fix it if it doesn't get sold)
PRICE - $2500 open to offers
CONTACT - i can be contacted on 0411607607 for a quick response otherwise a PM is fine.
at this point i'm not seperating anything so please don't ask.
cheers,
Kiefer
Edited by peakn7
not sure why,thought you had a sale pending you scanning the receipts and emailing me,have agreed the freight quote is reasonable :(
Peakn7 PMed me today, but you called it first, so its yours dude, ill pull out. If this engine is still here at the end of June then its mine.
mate that's very gentlemanly of you....strength and honour :thumbsup:
any sensible purchaser would want to see receipts so deal sealed on receipt of same
Edited by Z24O
np mate.
And yeh, would defenetly go check it out before making any payments. But yeh, this is a BARGIN.
ok guys, can't track receipts, they're with previous owner and he keeps telling me he can't find them but he'll keep looking.
engine is out and can be inspected.
PM's replied to.
still for sale at this point.
dont know what u guys need receipts for, its a cheap engine and receipts dont prove
a thing. Stop wasting peoples time, if u want the engine buy it off the guy,
good luck bud, free bump as well
your in perth aren't you buddy,there's one for sale over here in o'connor complete with loom(no ecu) asking $2000....this ones been for sale on the forum for over a week now,guess a few other interstaters may wish to see receipts for something they are buying on good faith(no matter how cheap it seems),can't speak for locals in SA
Edited by Z24O
since you weren't interested in separating a month or so ago...how about now?
I am after the complete top half, head, plenum, injectors, coil packs, loom, covers, cas, turbo lines.
if you're keen, pm me how much you'd be after plus postage.
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
