  • Replies 104
If anyone has any other options to what i have stated to get more kws out of the car plz give advice.
My budget reali is $2000 and im hoping to get -
- high flow from slide, around $1000
- Spitfire coils, $525 (needed!!!)
- Deatchworks injectors, around $550 deliverd (hopefully pick up second hand)
- Boost works tune, around $600
Total $2675 roughly. but then sell standered turbo very good cond $400? Injectors $100? So roughly $2000....
hoping to hit 270kws.....
any other ideas???
any other ideas???
Have you considered labour costs to fit your new turbo, injectors etc etc???
You also need to factor in a Z32 AFM as the standard AFM will run out of resolution at anything more than what you're currently running. Budget around $400 (or $200-$300 2nd hand).
I'd also be cautious about using deatschwerks injectors. From what i've read, they seem to get mixed reviews (everyone in the US loves them, everyone else seems to think they're crap). If you're after something tried and proven, then spend a few extra dollars and stick with something like Nismo or Sard injectors (you'll also need the injector collars for the Sards as they're not direct fit). Try Nengun for some prices. 550cc are good for well over 300rwkw, so probably no need to go for anything bigger unless you're planning more mods further down the track.
Do you have a full turbo back exhaust or cat back only? Cat back exhaust is still going to be quite restrictive and limit the power you'll make, so i'd recommend upgrading to a full exhaust if you haven't already done so.
Not wanting to put a damper on your enthusiasm, but I think you're going to struggle to make 270rwkw regardless, especially without upgrading cams. I think 250rwkw is a realistic target, so perhaps set this as your aim and count anything extra as a bonus.
thanks for that advice. yep its a full`turbo back stainless steel exhaust.... ill check out nengun thanks. oh and my dads mate is a machanic so hell help out wid the fitting etc
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
