I am very happy with the Wolf 3D plug-in myself. Do a search on both ecu's and you will find a wealth of information.
If you have a R32 why change you ecu, just get it rechipped? Even though i am very pleased with the wolf, it can never run as smoothly as the factory ecu. My problem was that R33 are not programmable.
i disagree that aftermarket ecu's can never run as smoothly as factory ones.
all you need is a good ecu, very competent tuner, and the money to keep going back for fine tuning.
afterall... factory ecu's are programmed by humans too... the only difference is that your average car manufacturer has a team of professionally educated boffins trained to tune their motors and the money to pay them.
if only your average joe was so lucky.
Well I think that aftermarket ECUs can run as well as stock ones, but if you go modding too much eventually idle and low rpm will suffer - not much you can do about it as things like bigger cams, injectors, penums optimised for higher rpm etc - it all adds up, which is something alot of people dont seem to realise when they head down the mod path.
I am quite sure someone will tell me about a beast of a car that totally disproves the above, but it is just what I have seen and experienced -
0.182c not including GST:)
OK, i felt this topic too open.
What i ment was that Millions of dollars are spent by the manufacturers to make an ecu run the engine and other parts, IN STANDARD FORM, really smoothly. This includes, cold, warm and hot start ups, fuel economy, a/c, and a whole lot of other shit.
I am very pleased with the running of my ecu and have no further problems, but with a R32 on can modify just the required areas/fields of the map to receive a VERY similar result.
Just my 2c
Alan
Guest drift_me_silly
it all comes down to application...for street, the factory chipped computer will always be the best value for money...and i hear what Turbo titts is saying; finetuning that takes place at teh factory has to take place at a workshop paid hourly by you to acheive the same or better results...the one and only thing that will always sway my mind back to the aftermarket is the resolution. -that also affects my choice of comp....but always, the resolution will be the defining factor of how thoroughly you CAN tune it. money money money......all that money....
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
